Sponsored by: Real Truck
Airbag removal
Old Jan 31, 2010 | 11:20 PM
  #31
bayou barataria's Avatar
bayou barataria
Yes they will charge you a service charge, just call them and ask it should not be too much and they will probably know what the problem is, they work on them all the time.
Old Feb 1, 2010 | 09:10 AM
  #32
kelly67's Avatar
kelly67
abs is fine
your abs is working as it should! if your truck is bouncing around do to rough suspension than as soon as weight comes off that wheel your brakes are going to lock up.an abs is working as it is suppose to do. your problem is your suspension not abs.
Old Feb 2, 2010 | 10:03 PM
  #33
jsparrow's Avatar
jsparrow
The whole suspension set up was just replaced though. Its not bouncing around, its pulsing furiously when i stop, regardless of the speed. It pulses a bit slower at slower speed granted, but it shouldn't do it at all if i'm not trying to stop quickly.
Old Feb 2, 2010 | 11:35 PM
  #34
redford's Avatar
redford
FTE Leadership Emeritus
The ABS activation is more like a buzz as felt in the brake pedal, not a pulse or shudder.
Old Feb 2, 2010 | 11:55 PM
  #35
kelly67's Avatar
kelly67
ok if your on level pavement an you try stopping and truck isnt riding rough your saying your abs is engaging? if this i the case can you check by wheel hubs to see if anything is in the way of sensor. if your truck is older it will only have abs in the rears.
Old Feb 3, 2010 | 08:35 AM
  #36
jsparrow's Avatar
jsparrow
Its a 2000. I'll check that out.
JasonBrod
Oct 26, 2013 04:11 PM
Ross Matthews
Jul 5, 2013 12:34 PM
crash1
33
Dec 29, 2011 05:50 PM
SSSimon
Australia Chapter
19
Jun 26, 2011 04:02 AM
Billy Blaggs
Nov 25, 2009 12:01 PM
