Modular V10 (6.8l)
2000 EXCURSION V10 HEATER WOES !!
Old Jan 7, 2010 | 02:08 PM
jessccs's Avatar
jessccs
Cool 2000 EXCURSION V10 HEATER WOES !!
My wife's 2000 Excursion is experiencing some heating problems .. if not fixed she's gonna drive my truck The problem is that for some reason or another the heater will go from defrost to heat etc. spasmaticaly. I can hear a flapper flap when it changes from heat to little heat. It did the same with the air conditioning. I did replace the heater fan blower, but that didn't have any effect (the blower motor was screeching). Hope some one has a easy/quick fix remedy for this problem. HEY, WE GOT SNOW !!!
Thanks, jessccs
Old Jan 7, 2010 | 04:49 PM
dkf's Avatar
dkf
There should be a vaccum operated valve on the heater hoses that block off coolant to the heater core when the A/C is running. If the vaccum line came unplugged it won't work. Just off the top of my head, its easy to check.
Old Jan 7, 2010 | 11:50 PM
NM04FORD's Avatar
NM04FORD
There is an actuator motor on the blend door, which moves the door to mix hot and cold air. It could be going out, our Tuarus has had it go out 2 times when it goes out it's nothing but hot air for the Tuarus, both times it happened in mid summer.
Old Jan 8, 2010 | 08:35 AM
bigdaddymedic2000's Avatar
bigdaddymedic2000
is your EX a 4x4... check and see if the 4x4 will engage...not just the lights showing 4x4. my EX had bad front hubs ( they use the same vacuum that runs the heater / ac vent door). there is several post up in the excursion discussion. replacing the auto hubs ($ 325.00 each from ford) to warn manual hubs ($194.00 pair) cured my problems.
Old Jan 8, 2010 | 09:46 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Going to defrost is a typical vacuum leak situation
78crewcabjohn
Feb 23, 2015 05:28 PM
JSpring
Nov 12, 2013 04:55 PM
sjones47043
Feb 5, 2007 06:57 PM
bozo4ford
Mar 31, 2006 03:25 AM
Dett
May 10, 2004 08:35 AM
