Starting issues
Old Jan 7, 2010 | 01:06 PM
jsmithis101's Avatar
jsmithis101
Starting issues
Hello All, I have a 2008, F150 5.4 SC. It has been Farily cold here in the mornings between -16 and 10. Last Saturday I had to have it jump started, it would not crank. When you went to turn the key you would hear some relays clicking, but nothing coming from the starter, also when i turned the key off the gauges where flickering mostly the tach, and speedo.
Well this Tuesday it needed jumped again, this time it would crack but not enough power to turn over. I was due for a oil change so i figured I'd just have them test the battery, well it tested with 540CCA, (anyone know what the factory battery is rated for at CCA? It's still the stock battery)
I have read previous posts where they experienced the same thing, replacing the battery fixed it. So I'm wondering even though it tested OK at the stealership, is my issue the battery or something else ?
Thanks,
Old Jan 7, 2010 | 03:47 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
Sounds like it won't hold a charge to long anymore 540 CCA is very low for these trucks I would get a new one with at least 850 CCA or better.Think the stock is an 540CCA should be on the top of battery.
Switched mine to an 850 CCA and no more problems.
Old Jan 7, 2010 | 06:29 PM
jsmithis101
Ok. Any brand preference? I've heard interstate isn't worth a darn. Any idea what the ford part number is ? How does the 850CCA battery fit ?
Old Jan 7, 2010 | 06:32 PM
Wilber15's Avatar
Wilber15
It'll fit fine, the battery box is larger then the 550 battery. Also some f150's were manufactured with the bigger battery. so you'l have no issues.
Old Jan 7, 2010 | 06:37 PM
jsmithis101
Ok, cool thanks.
Old Jan 8, 2010 | 02:21 PM
2004 xlt 5.4
I have the Ford one no problem with fit around $120.00 have used ford battery since my 1988 F150 never any problems normal life 3-4 years
Old Jan 8, 2010 | 02:39 PM
rdalley's Avatar
rdalley
the Everstart Maxx 65-N from walmart is a great battery. Ive used it in my f150 and dads superduty diesel. Has 850 CCA and turns my truck over faster than it ever has.
Rusty Axlerod
Feb 28, 2023 11:19 AM
sunuvabug
May 29, 2014 07:18 PM
AndeyHall
Oct 4, 2011 04:47 PM
Plat7.3
Sep 17, 2007 08:18 AM
