dieing motor
Old Jan 7, 2010 | 11:11 AM
gfgecko's Avatar
gfgecko
dieing motor
2000 excursion with v-10, no compression in # 5 and 10 cylinders. all plugs intact. Problem, rough running, started with nearly empty tank. any suggestions.
Old Jan 7, 2010 | 12:15 PM
jdadamsjr's Avatar
jdadamsjr
Hmmmm....
NO idea as I don't have a v-10,
but empty tanks bring up ideas of trash getting into filters, etc....
considered a tank to engine clean out ? or at least fill up to dilute fuel and clean out filters ?
Old Jan 7, 2010 | 12:22 PM
Downriver Thunder's Avatar
Downriver Thunder
If you have no compression then it might be a bad head, head gasket or rings. I only got 200k out of my first motor.
Old Jan 7, 2010 | 10:58 PM
UrbanXX's Avatar
UrbanXX
May I ask how did you determind that there is NO compression on these two cylinders numbers 5 and 10?
What did you do to arrive at zero compression?
What compression do the other cylinders have?
