pinion???
Old Jan 6, 2010 | 10:21 PM
traxx808's Avatar
traxx808
pinion???
hey guys......i was on ebay during the xmas season looking for 3.55 gears and i noticed that the length of the pinion shafts were different. some were long and some were short. i was thinking why this was. i wanted to purchase gears this holiday season and did not do it when i saw this. does anyone know why its different?? was looking for the 8.8 ring and pinion. is it different from car to truck?? its going on a 94 f150 2wd. when i had emailed the different sellers through ebay they all said it did not matter and it would fit. i wanted to ask you guys this question before making a purchase and would not be able to return it to the seller............thanks for the feed back guys.................
Old Jan 6, 2010 | 10:59 PM
Hitokori's Avatar
Hitokori
it depends on the housing like dana 30 or 8.8 and so on....
i wouldnt think they would make 2 different legths for a 8.8 inch for a truck and a 8.8 for a car
Old Jan 6, 2010 | 11:00 PM
TexasGuy001's Avatar
TexasGuy001
I am fairly certain that 8.8 ring and pinion gears are interchangable between all 8.8 diffs. I know that you can use Mustang, Explorer, etc gears in our trucks. I have never heard of there being any difference. Its possible that maybe different bearings are needed though.
Old Jan 7, 2010 | 03:58 AM
lew52's Avatar
lew52
The ring & pinion should all be the same for the 8.8 , the carriers are different , cars , mustang 28 spline , trucks 31 spline ....Lew
Old Jan 7, 2010 | 04:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
9L3Z4209A .. 8.8" R & P 3.55-1 / 9L3Z4209A replaced 5L3Z4209B, E7TZ4209B and etc.
Fits: 1983/2010 F Series Trucks, Econoline's & etc. / 1983/96 Bronco // 1987/ Passenger Cars.
Old Jan 8, 2010 | 12:01 AM
traxx808's Avatar
traxx808
thanks for the feed back guys.......i will be looking for the gears today.........
Old Jan 8, 2010 | 12:56 PM
blakem_85's Avatar
blakem_85
Actually, the carriers are the same but the side gears are different, with the exception of there being an old style and a new style carrier.
Old Jan 8, 2010 | 01:10 PM
lew52's Avatar
lew52
Right , you can't put 31 spline axles in a 28 spline carrier...
Old Jan 8, 2010 | 05:38 PM
blakem_85's Avatar
blakem_85
Just meant the carrier will swap IF you change the side gears (the splined gears that the axles go into). Had a pinion nut come loose on mine which resulted in a cracked carrier but it didn't hurt the spider gears. Ended up getting a 28 spline carrier for free and swapped out the gears, making it a 31 spline.
Thor'sHammer
Nov 26, 2014 05:48 AM
Rusty_S
Feb 26, 2014 12:38 PM
624WD
Jan 25, 2014 08:46 AM
austinr09
2004 - 2008 F150
Jul 11, 2012 08:31 AM
Newcomer
Offroad & 4x4
61
Apr 22, 2011 10:05 AM
