injectors
Old Jan 6, 2010 | 01:16 PM
Uncle Shank's Avatar
Uncle Shank
injectors
i may be needing a new injector and was wondering how much would one cost to get replaced?
Old Jan 6, 2010 | 01:43 PM
w_huisman's Avatar
w_huisman
Please provide a bit more info, Shanky. What year is the truck? Are you doing the work or are you paying someone else to do it? Is the truck under warranty? etc...
If you're doing the work yourself, I'd probably recommend getting a rebuilt injector from River City Diesel (~$160), or some other similar source that is well respected on the diesel forums.
If you're under warranty, Ford should do it for you for a $100 deductible.
If you're out of warranty and hiring an independent shop to do the work, I would recommend thoroughly researching your potential shops to insure their competence.
Old Jan 6, 2010 | 07:39 PM
cheezit's Avatar
cheezit
350 per injector and 400 labor per a side is about avarage.
Old Jan 6, 2010 | 07:43 PM
foul1's Avatar
foul1
I found a tech that will change a side for 1350.
Old Jan 6, 2010 | 07:54 PM
cheezit's Avatar
cheezit
not bad for a side job price. Hmmmm maybe I need to find some people that need injectors too.
Old Jan 6, 2010 | 07:58 PM
foul1's Avatar
foul1
Its a couple of former Ford techs just startin out told me the injectors were 260 each and same labor more or less to do the two weak ones as all 4
Old Jan 6, 2010 | 08:48 PM
Uncle Shank
Its a 2006, I am having the dealership to do it, its not under warranty. The man I talked to told me that they installed the injector flash or reflash, what ever it is, and that since it was still starting hard that it could be an injector. It also threw a code, but I'm not going to be able to know what it is until tomorrow or friday
tpc3
Dec 13, 2013 08:36 PM
danielwd
1983 - 2012 Ranger & B-Series
Jan 2, 2011 10:18 PM
turbill
Dec 22, 2010 06:59 PM
SAltonS
Dec 18, 2009 08:36 PM
Nathan
Aug 5, 2001 08:58 PM
