Sponsored by: Real Truck
Oversteering
Old Jan 6, 2010 | 10:21 AM
Downriver Thunder's Avatar
Downriver Thunder
Oversteering
On my 05 250 5.4 FX4 I noticed within the last month or so that it seems to really want to oversteer. I had new tires, (285's put on), and it had every linkage, tie rod and ball joint replaced last November followed up with an alignment. After the work all was good although the steering wheel was turned a bit to the right but nothing I couldn't deal with, I was able to finally always see my XM display . Here within the last month it seems to have alot of slop. You can turn the wheel from say 11 to 1 oclock with little reaction from the truck but when it does react it really pulls in that direction. Any thoughts? I do have a dual Rancho stabilizer on it that was added last December.
Old Jan 6, 2010 | 10:56 AM
cartmanea's Avatar
cartmanea
If it has developed slop that quickly, stop driving it until you get it checked out as there could be something coming loose.
Old Jan 6, 2010 | 11:09 AM
senix's Avatar
senix
might have the alignment and all components rechecked. Maybe rotate the tires first and see if that helps.
