will the trans and transfer case out of a 92 460 truck work behind my 7.3. I really only need the t case but I can get the trans for an extra 200 an its recently rebuilt. thought for that I would throw it in while i was under there.
ok then thanks, the tcase should work fine though I assume? also does anyone know if I could put a 6 speed from a superduty in my truck or is it not worth it just go with the 5speed if I am going to do a manual conversion
Go over to powerstroke nation, this same exact topic came up, basically the end result was, same highway speeds, 200rpm drop and aPITA to mold the floor boards to fit, obs has a lowersloor, lkess clearance
I don't rember the final drive gearing numbers but if you church 70 at 2250rpm it was about a 200 rpm drop. Some guy was trying to sound smart saying it was a waist of time and the final drive was the same, and the guy who did a swap came in a shut him down lol over all it wasn't really worth the swap, but if you get a killer dseal on a 6spd and a 30rack of beer and a buddy to help ya, then hell yeah man do it up
BTW sam, how goes the settling in? You ready for this chip yet? Lol id be antsy and excited like a little girl haha
does anyone know if the f150tcase will be the same I founfdone local and dont need to drive clear accross the state to pick up the one I found out of a f350. thanks in advance for the help
I think we're looking for the overdrive ratio of the manual vs. automatic. The six speed manual is 0.72:1. I think the five speed is the same, but I'm not certain. The automatic is 0.71:1 in overdrive. So the automatic will run a few less RPM at the same speed. The difference is so small that it doesn't matter.
