223 or 300?
Old Feb 1, 2000 | 05:32 PM
MGFIRE23's Avatar
MGFIRE23
223 or 300?
I think I might have found a way to distinguish between the 223 and 240/300. Can some one tell me if this is accurate or not. I was told the 240/300 has more bolts int the valve cover(8) than the 223(6) is this accurate or not. i was also told the intakes are on opposite sides. I found a stamp on the block on the driver's side front near the top that says "262T" does anyone know what this means? If it is a 240/300 how do i tell the diff? Sorry for all the questions I'm waiting on the books to arrive.
64 F-100 Vin:F10BR500897
I checked stockman's page are those codes valid for earlier models. You all have been a great help I appreciate it alot
matt
mgfire23(No Email Addresses In Posts!)
Old Feb 2, 2000 | 01:56 AM
Jim_V's Avatar
Jim_V
223 or 300?
I think the 262 was a larger displacement version of the 223.I also think that a very easy way of telling a 223 from a 240/300 is the shape of the valve cover as the 223 is just a rectangle while the 240/300`s have humps on side,also I believe the 223 only has 2 bolts holding the valve cover on,like on the Y-Block V-8`s,and yes,the manifolds are on opposite sides.
Old Feb 2, 2000 | 07:04 AM
Nathan's Avatar
Nathan
223 or 300?
Matt
The 4th digit, B, denotes a 262ci I6 in your vin.#. With the # you found this is probably what you have.
Nathan
Old Feb 2, 2000 | 11:29 AM
big60's Avatar
big60
223 or 300?
I believe that the easy way to spot the difference between a 223 and a 240/300 is that 223 engines have the carburetor & intake/exhaust manifolds on the drivers side whereas the 240/300 is on the passenger side
Old Feb 2, 2000 | 06:44 PM
BRAD_1's Avatar
BRAD_1
223 or 300?
hillcountryflt
Feb 12, 2015 03:42 AM
1986F150six
Mar 16, 2012 08:46 AM
Syntheglass
Aug 20, 2004 08:56 PM
bhabben
Feb 2, 2003 09:57 PM
