Rough idle
Old Jan 6, 2010 | 12:16 AM
davewave649's Avatar
davewave649
Rough idle
The idle on my 302 seems rough and after if i run it too hard the idle gets so low that i have to shift into neutral and rev the motor to keep it from dieing, and also the truck seems to cycle when its at idle, does anyone know how to fix either of these problems?
Old Jan 6, 2010 | 12:31 AM
63' f100's Avatar
63' f100
my 292 kinda did that. when it was cold it would idle fine, but slowly go down in RPM and eventually it would just die if you didn't rev the engine every 30 seconds or so.
I rebuilt the carburetor recently and it idles very well now and does not hesitate like it used to when it pressed the gas.
If it still has the original carb on it, i would recommend rebuilding it. its about $20 for a rebuild kit and its well worth it. just be sure you get that carb really squeaky clean and all the dirt and carbon off. be very careful and pay close attention to it when you take it apart. the diagram that comes in the box isnt very good. i suppose it depends who makes the kit, but the one i had wasnt very helpfull at all. it just said "reassemble oposite of dissassembly", which wasnt very helpful.
when you rebuild it you will need the type of carburetor it is. saying "a 2 barrel on a 1963 292 f100" wont cut it, as there are 3 kits available from napa under that description. the number is on thin piece of steel bolted on the carb. on mine you had to remover the airfilter to find it and i had to scrap the dirt/mud/crud off to read it.
i dont know for a fact that that is your problem, but i would be willing to bet it is.
Old Jan 6, 2010 | 02:22 AM
macgiobuin's Avatar
macgiobuin
My 302 did the same thing and it took TWO things to fix it: carb re-build as has been mentioned AND a new fuel filter.
Old Jan 20, 2010 | 06:13 PM
jsimon23's Avatar
jsimon23
I have run into this issue with my 302. I doubt the carb is all that old, so I don't think it needs a rebuild, but maybe changing out the fuel filter will help. I was hoping I just had to readjust the idle speed and fix the issue.
Old Jan 21, 2010 | 12:11 AM
davewave649
I had the idle speed raised because the rebuild did not fix the problem (however the rebuild was long overdue anyway) and that fixed the problem.
MentalState
Apr 10, 2014 11:34 AM
n20
Nov 6, 2009 08:20 AM
ryzl30
Arizona Chapter
Jan 28, 2008 02:41 PM
Truckerteacher
Oct 29, 2005 10:47 PM
