Kick Panels
Old Jan 5, 2010 | 08:45 PM
mytbtruck's Avatar
mytbtruck
Kick Panels
I made my kick panels and covered them with vinyl. Speakers will be install in them and also two rear speakers.
Old Jan 5, 2010 | 08:52 PM
Julies Cool F1's Avatar
Julies Cool F1
Those look great! I did the same thing - Masonite 1/4 inch! I haven't covered mine yet though.
Old Jan 5, 2010 | 09:03 PM
mytbtruck's Avatar
mytbtruck
I used 1/4 inch luaun plywood, Had to add a tapered strip on the front at the bottom coming up the side to fill the gap. Need to put screws in to hold it. Started to use carpet but changed my mind. Am I allowed to do that?????
Old Jan 5, 2010 | 09:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I started out the same as you, but switched to 1/16" aluminum due to the weight of the speakers, and concerns with mounting them to the plywood. Depends how heavy your speakers are.
Old Jan 5, 2010 | 10:09 PM
nordvik72's Avatar
nordvik72
Pretty cool did you make your own pattern? I need to do the same with my 56 but not sure what im going to use for the material yet.
Old Jan 5, 2010 | 10:38 PM
AXracer's Avatar
AXracer
Hardboard, ABS plastic, aluminum, 1/8" ply doorskin, upholstery board, even FG resin impregnated stretch fleece pulled over plywood forms will work if you want flowing shapes. I'd suggest putting a layer or two of polyfiber quilt filling (~1/2" thick fiberfill "blanket" sold at fabric shops and Wal mart) cut to the backing size to give the covering a pillowed padded look.
ssg1957
Jan 31, 2015 12:37 AM
Fifty-Fourd
Apr 2, 2011 09:12 PM
josh04hdf250
May 7, 2007 01:46 PM
schmidt64
Dec 25, 2005 12:05 AM
Big Daddy Braddy
Dec 17, 2005 09:10 PM
