Getting ready to remove the intake
Old Jan 5, 2010 | 08:43 PM
97FRD1TN's Avatar
97FRD1TN
So i'm finally getting ready to remove my intake manifold due to a broken bolt,so I have been looking through the archives to see what kind of information i could find.I found most everything that i need except a few things.First of all what kind of tool do i need to disconnect the fuel line?Is there a special name or is it just called a fuel line disconnect?Secondly do i have to remove the distributor or will i get lucky enough to keep it in?Finally to anyone that has done this,how long are we looking at barring not too many broken bolts or any other kind of problems.
Old Jan 5, 2010 | 08:47 PM
Hitokori's Avatar
Hitokori
Zip Code Select | O'Reilly Auto Parts $10 for the set
u have to remove the distributor
dont know how long it will take u
lol it all depends on the weather
Old Jan 5, 2010 | 08:54 PM
97FRD1TN's Avatar
97FRD1TN
Lol it can be 20 below out for all I care.I have access to a heated pole barn,that's why it has taken me so long to do because i had to wait for after new years.She's all mine now.
Old Jan 5, 2010 | 09:13 PM
rainbowATF's Avatar
rainbowATF
Don't forget to remove torks head bolt behind upper intake middle. I think it's a T-40 and you need to come down from the top between runners. I use a torks head socket and adapted to long 1/4" extension. Also 4 bolts at middle of lower intake manifold can be hidden in dirt. If lower does come up with gentle nudge; dig around for more bolts. I watched a determined neighbor destroy an intake with a prybar and hammer. Take your time. I just pulled all my injectors with fuel lines and cables attached and laid to one side b4 I removed manifolds.
Old Jan 5, 2010 | 11:19 PM
97FRD1TN's Avatar
97FRD1TN
Yeah I was reading up on removing that bolt and the tools that are needed to remove it.Doesn't sound to bad if you have the right extension and such to remove the torx bolts.So do I understand this right...you leave the injectors in and fuel rail but just disconnect fuel line back by the firewall?
Old Jan 6, 2010 | 08:45 AM
deeznuts822's Avatar
deeznuts822
If u are in fact removing the upper intake, then u will need a 1/4 inch drive socket, extension and a t40 socket that one would use in a drill. I welded the bit into a 1/4 socket and it worked perfect to do the job at hand. The fuel rail dont have to be removed unless you are pulling the lower intake as well
Old Jan 6, 2010 | 03:06 PM
97FRD1TN's Avatar
97FRD1TN
Well looks like I gotta pull the fuel rail,cause I also have to remove the lower intake as well.
Old Jan 6, 2010 | 04:07 PM
rainbowATF's Avatar
rainbowATF
I didn't remove fuel line just pulled rail to driver's side along with harness cables. B4 assembly I pulled each injector and replaced o-rings and reinstalled them. They (o-rings) were in the Fel-pro intake gasket kit.
Old Jan 6, 2010 | 04:18 PM
lew52's Avatar
lew52
X-2 you don't have to remove the fuel line , you can just get the rail out of the way & zip tie it ...
