Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Idling issues
Old Jan 5, 2010 | 06:29 PM
76EconolineND's Avatar
76EconolineND
Idling issues
Hello, I am searching for some help with my sisters 01 Mazda Tribute. I know this is the Ford site, But I know the escape and tribute are similar. Ok, it is a 01 Trubute with the 3.0 v6, automatic, 4wd. The vehicle was starting to idle extremely rough at start up and would occasionaly die. Eventually the check engine light came on. Hooked up the scanner and got some O2 codes and one that said we had a cylinder 1 misfire. How hard is it to change the plugs? I have read that the upper intake has to come off, is there a less invasive way? Also what other things should I look for or check. Thanks for any help.
*UPDATE*
Ok, got the plugs changed finally. Seemed to run a bit better. Took it for a test drive and it missed a little and felt like the motor was really holding back. Got it back to the shop and popped the hood and the front exhaust manifold was glowing orange hot. Could exhaust now be plugged? I don't know what to check for this other wise. Any more tips would be great.
Old Jan 5, 2010 | 06:45 PM
skibender's Avatar
skibender
Try cleaning the IAC. Lot's of info on here. Search and you should find instructions.
Old Jan 5, 2010 | 09:01 PM
triskadek's Avatar
triskadek
Changing the rear bank does involve the intake manifold
A code indicating a misfire in one particular cylinder could mean its just be time for a new coil pack. Easy enough to test, assuming you get a regular code reading. If it says it's cyl 1 that's bad, swap coil pack 1 with whatever is easiest to reach and test again. If the problem follows the coil pack to the next cylinder then order up a replacement. I've done fine with a $50 one from NAPA, as opposed to at least $90 (US) from a stealership.
As for just giving it a good cleaning, you could try the smokeshow which is seafoam, you feed it into the system through a vacuum line, let it stall, and sit for a few minutes.
Old Jan 6, 2010 | 12:07 AM
bmuhlbach's Avatar
bmuhlbach
How to replace your V-6 Escape's spark plugs
i bumped the thread it is a great how to
Old Jan 6, 2010 | 07:52 AM
EBTDM's Avatar
EBTDM
http://www.ford-trucks.com/forums/453729-how-to-replace-your-v-6-escapes-spark-plugs.
Are the plugs original, and how many miles on the plugs? There is a great thread here on changing the plugs. ( https://www.ford-trucks.com/forums/4...ark-plugs.html ) It is really not that hard.
Old Jan 6, 2010 | 11:54 AM
bmuhlbach's Avatar
bmuhlbach
no.1 coil pack is under the intake on pass side. The plugs should be changed at 100,000 miles.So if its there or close to that i,d change them.Also pvc valve is easy to get at and i would replace the lower and upper intake gaskets.And inspect the vacuum lines.Mine had the same code but misfire in 3. found the bigger vacuum line on back off intake was bad.
Old Jan 6, 2010 | 02:33 PM
jonboko's Avatar
jonboko
where is pvc 3.0
Old Jan 6, 2010 | 11:27 PM
bmuhlbach's Avatar
bmuhlbach
under intake on driver side of engine.
Old Jan 7, 2010 | 07:43 AM
76EconolineND
update
I won't have a chance to work on the car til this weekend. Oh and its got 147,000 miles on it with most everything original.
Old Jan 9, 2010 | 09:46 AM
zangledworf's Avatar
zangledworf
I have an 01 with about the same miles. It started doing the same thing so I went ahead and changed the all the coils and the plugs in back, seems a little over the top bit I didnt want to have to pull the manifold again for a while. I found coils for 35 bucks each which isnt to bad so I figured with the miles it was worth it. But after changing everthing about a day later it started sputtering again so I put a code reader on it and was told it was bad #3 so I pulled the coil and plug and put it up front and replaced it with a good one and the problem ended up being the new plug I had put in. So when you pull the manifold make sure you try to move your problem to the front bank so you dont have to do more work than need be.
Old Feb 7, 2010 | 12:58 PM
76EconolineND
bump please help
Old Feb 7, 2010 | 09:42 PM
bmuhlbach's Avatar
bmuhlbach
if your manifold is glowing orange there is a issue with that don't know if it has a butter fly on that manifold that is frozen.the butterfly flap would close forcing the exaust gas to go across the engine to bring it up to tempature faster. or a plugged up catalytic converter.also when you did the plugs did you do lower and upper intake gaskets?
