4 spd alternatives needed
Old Jan 5, 2010 | 11:18 AM
NCTowMaster's Avatar
NCTowMaster
Hi Folks, I've been doing a lot of looking on here..but without knowing what I'm looking for it's like chasing my tail. I've gotten my hands on a 1986 F-250 Diesel 2wd 4-spd manual. The clutch needs replaced which is on my to-do list certainly, but it does drive. What I can't stand is listening to the engine sound like it wants to fly apart at 60mph because it's only a 4-spd. I keep reading there is a swap to something like a ZF-5 tranny that can be done. Every thread I find that talks about it includes those that say it's a straight remove and install swap, and those that say theres a hundred different things that I need a machinist to design. I'm a competent gearhead but Diesel's are a new world to me. Anything I can do for another transmission?
Old Jan 5, 2010 | 11:42 AM
mechelement's Avatar
mechelement
Subscribing.
I've read Clark 5-speed overdrive manual transmissions will fit too. I believe our motors have an SAE 3 bolt hole pattern for bell housings, so the selection is sparse. I'm sure you can really bolt anything up to it with the right adapter.
Is a Getrag 360 an SAE 3 bell housing transmission??? They were found on the Gen 1 12V Cummins.
Old Jan 5, 2010 | 11:55 AM
NCTowMaster
What I'm worried about is needing an adapter, then worrying about fancy flywheel depth differences and driveshaft lengths. And more importantly than knowing I need them is knowing what to get and where to get it from.
Old Jan 5, 2010 | 12:24 PM
starmilt's Avatar
starmilt
The zf5 speeds from 88 to 93 will bolt in with all ford parts. they use a dualmass flywheel but you can use a single mass,but you have a noisy tranny at idle.
On the 2x swap it would fairly straight forward swap especially if you get a donor truck.
Before you replace your clutch have somebody mash the clutch while you watch the master cylinder if it moves the firewall needs reinforcing on the inside. I have also had the bushings in the clutch pedal mechanism be loose enough to have enough play it wasn,t pushing the mastercylinder rod far enough.
On your motor sounding like an air plane you probably have 4.10 gears in the rear end unless you are pulling big loads you would be better off changing to 3.55's or higher.
You might check your clutch fan and make sure it isn't locked up as it will sound like it is ready for take off no matter what gears you have if it is.
The rpm's at 60 isn't hurting it but it isn't good on fuel either.
Old Jan 5, 2010 | 12:26 PM
starmilt's Avatar
starmilt
Actually the 5 spds will only work up to 92 because of the speedo provision.
Old Jan 5, 2010 | 12:30 PM
starmilt's Avatar
starmilt
I forgot to mention When ford went to the ZF5 the bellhousing is intergrated with the transmission so it HAS to come from a diesel NO gas ZF5 will bolt up.
Old Jan 5, 2010 | 12:51 PM
NCTowMaster
Thanks a ton guys. Starmilt, so If I found a ZF5 from a diesel in those years you listed before, I would not have to worry about an adapter plate?
Here's what I'm thinking for the swap. Please yell at me if I'm off:
The ZF5, from those years and from a diesel.
The ZF5 throwout bearing and clutch hardware.
Cuttin a little of the floor pan for shifter relocation
Dual Mass to Single Mass conversion from LUK...or just leave that alone?
Old Jan 5, 2010 | 12:56 PM
starmilt's Avatar
starmilt
I like the single mass,but I like to keep things simple and the dualmass does not last as long in my opinion.
You will not need an adapter the later model 7.3 stroke trans will even bolt up but you will lose your speedo beginning in 92.
Im'm thinking the drive shaft is different.
Old Jan 5, 2010 | 01:45 PM
Fishin76's Avatar
Fishin76
Whatever truck you get the ZF-5 out of, get the rear driveshaft too. You can always have shop shorten or lengthen it, but at least you'll have the correct ends.
Old Jan 5, 2010 | 04:44 PM
LCAM-01XA's Avatar
LCAM-01XA
Originally Posted by mechelement
Subscribing.
Clark 285VO is the one needed IIRC, I'm keeping my E4OD till I find one of these then I'm going bolt-action - ZF5 is alright trans, but I want bulletproof medium-duty stuff, for that one time when I have to gross at over 30k again...
Old Jan 5, 2010 | 06:41 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Actually the ZF 5 made it's first appearance behind the 6.9 in 87.
Old Jan 5, 2010 | 06:50 PM
starmilt's Avatar
starmilt
I was 99% sure but was 110% sure 88's had them. Thanks Dave.
Old Jan 5, 2010 | 10:12 PM
NCTowMaster
Thanks a ton everyone, just solved a lot of headache for me right off the bat.
I'm surprised any diesel ZF5 from 87-93 will bolt up to a 96 6.9 but like I'd said, came in with no experience with diesels or Ford's.
Old Jan 5, 2010 | 10:36 PM
LCAM-01XA's Avatar
LCAM-01XA
The 6.9 and the 7.3 IDIs, along with the early 7.3 PowerStrokes, share the same transmission bellhousing bolt pattern - so a trans from a later 7.3 truck will fit an earlier 6.9 and the other way around.
Yeehaw1
Oct 2, 2012 06:12 AM
jwth2005
1997 - 2003 F150
Feb 22, 2011 12:20 AM
GarageFab
1983 - 2012 Ranger & B-Series
Oct 19, 2010 12:12 AM
64fordf100292
Aug 19, 2009 07:56 PM
