Sponsored by: Real Truck
Keyless Key Pad Not Working
Old Jan 4, 2010 | 04:15 PM
blk04crew4x4lariat's Avatar
blk04crew4x4lariat
I am no longer able to use my key pad to get into my truck - 2004 F-250 V10. I think it might need a battery, but when I called the dealer they said I have to replace the whole thing, not just a battery. Has anyone else had this problem? I ordered at the time I ordered the truck new in 2004.
I can't find a post anywhere that can answer this.
Thanks,
CEM
Old Jan 4, 2010 | 04:35 PM
bpounds's Avatar
bpounds
The factory version is wired into the truck. The glued on version is a dealer add-on or aftermarket and those use a battery.
The guy you talked to probably believes yours is wired in.
You will have to determine whether it is. The battery powered add-on version is usually thicker and looks kind of cheezy, and the top just pries off the change the battery, or so I've read.
Old Jan 4, 2010 | 05:21 PM
powerstroke72's Avatar
powerstroke72
The keypad should look like one of those below. As Bill said,the thicker model is the add-on and has its own battery. If it's more of a flush mount like the other picture, it runs off the vehicle's electrical system. I'm guessing since yours is an '04 model, it's the add-on unit. If so, below is a link to a battery replacement write-up with pics:
2004 F250 Keypad Battery Replacement
While the pics above aren't on Super Duties, you get the idea. The battery replacement in the add-on unit is pretty simple and straight forward.
Old Jan 4, 2010 | 05:30 PM
bpounds's Avatar
bpounds
Good find, John.
Old Jan 4, 2010 | 05:34 PM
powerstroke72
Originally Posted by bpounds
Good find, John.
Thank you sir....just following up your always good advice.
Old Jan 4, 2010 | 05:37 PM
blk04crew4x4lariat
Thanks - mine looks like the second one, so I'm assuming it's the add-on. I'll try to pry it up so I can replace the battery.
CEM
scottzj
Nov 6, 2022 10:48 AM
bkuuz1
6.7L Power Stroke Diesel
Sep 27, 2016 09:37 PM
racin
1997 - 2003 F150
Mar 13, 2016 08:59 PM
vtjvt
Oct 6, 2015 09:23 PM
n4aof
Jan 6, 2009 09:12 PM
