Won't cold start
Old Jan 4, 2010 | 01:49 PM
sailorjohn's Avatar
sailorjohn
Won't cold start
I have a 1999 E-350 7.3 diesel. When the temp is over 20 degrees or when I use the oil heater it starts well but when the temp drops below 20 and I don’t use the oil heater I can’t get the truck to start with out a jump. I’m assuming that this is not normal where should I look for the problem?
Old Jan 4, 2010 | 02:03 PM
PwerStroke99's Avatar
PwerStroke99
check your glow plug system
Old Jan 4, 2010 | 04:29 PM
c125bob's Avatar
c125bob
RIght....... check your Glow Plug Relay first. Also a good time to take a wire brush to the battery terminals and clean them really good even if it looks like they don't need it.
Old Jan 4, 2010 | 04:41 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Yup those are the basic two thing that will keep it from starting in the cold weather. Of just move to south florida :-)
Old Jan 4, 2010 | 05:03 PM
c125bob's Avatar
c125bob
Heck, it's so cold here in Georgia I can't believe it ! I don't know how our Brothers and Sisters up North stand it. I've let my 7.3 sit the past few days and have been driving my Jeep. If I have to pull something or go further than 10 miles to town I'll fire up the beast.
Old Jan 4, 2010 | 06:02 PM
torquemeister's Avatar
torquemeister
Have you checked voltages yet? All of the below applies to an 03 F250, hopefully it's accurate for a 99 E350 as well.
Sounds like the batteries are taking a beating from your cold weather (32* weather in TX stranded me on Christmas Eve with weak batteries).
The PCM won't turn the injectors on if the engine RPM is not fast enough - does it seem like it's turning over slowly or at normal speed?
Also, the glow plug relay should be checked - you should have the same voltage as the batteries on both of the large studs when it's cold and the key is on. This is a large draw on your batteries when it's working.
-Chris
06FUN
Oct 29, 2016 07:53 AM
redman84
17
May 29, 2013 12:38 PM
DeadBody
16
Dec 30, 2012 09:32 PM
ten.mile
Dec 11, 2012 05:56 PM
Bob97F350
19
Apr 13, 2009 05:10 AM
