Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 11-20-2014, 07:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
Print Wikipost
Looking for other C series owners
  #241
Old 01-03-2017, 04:50 PM
Merlin Monson's Avatar
Merlin Monson
Merlin Monson is offline
Ford used the same engines in the c series and the f series. I would walk in to the local parts store and If possible try and find an older parts guy that perhaps has been in the business for some time. Just explain what your wanting to do and it should not be a big problem. As far as the clutch master cylinder goes, I am not at home or i would look at my truck but i want to say there is a fill plug on the matter cylinder to add fluid.
  #242
Old 01-03-2017, 05:18 PM
Destroked 450's Avatar
Destroked 450
Destroked 450 is offline
Yes the master cylinders have a tab on the boot for pulling it up so you can add fluid into the top of the master cylinder.
Yea when mine needed fluid I had to ask a friend that used to work at our local Ford dealer back in the day where to fill them.
All Ford V8 points and condenser are the same, cap and rotor button also the same on points dist. I'm thanking 477, 534 used the same plug as FT engines that would be a F10 in a Champion, can't remember the Autolite number.
  #243
Old 01-03-2017, 05:43 PM
scf100's Avatar
scf100
scf100 is offline
thanks guys
  #244
Old 01-03-2017, 05:49 PM
William Cabot Boyd's Avatar
William Cabot Boyd
William Cabot Boyd is offline
Originally Posted by scf100
got one with 20k miles.....now where to buy engine parts for tuneups etc?
how to add fluid for hydraulic clutch?
I would recommend that you purchase a transfer pump.
http://m.acehardware.com/product/index.jsp?productId=1450792&KPID=1251953&cid=CAPLA :G:Shopping_-_Lubrication_Products_-_New&pla=pla_1251953&k_clickid=73fec5ad-a179-4416-b707-bf8c3cc20778
this is the easiest way to get fluid into the brake reservoir and clutch reservoir. This will allow you to control the fluid.
Be aware the clutch And brakes can be notoriously difficult to bleed because if the bends in the line.
I love your fire truck!!!
  #245
Old 01-03-2017, 07:30 PM
scf100's Avatar
scf100
scf100 is offline
Thanks,
So next question is where is the bleeder screw located for the clutch?
  #246
Old 01-03-2017, 11:36 PM
roKWiz's Avatar
roKWiz
roKWiz is offline
scf, nice truck mate.
Thought this might help. (sorry about the display size !)
  #247
Old 02-15-2017, 04:38 PM
garyscc's Avatar
garyscc
garyscc is offline
Just got a 1972 c700 4x4
Hi all, just bought a 72 c700 4x4. It was a pg&e vehicle that i was told was hardly used. It was a special factory order that was completed by fabco for the 4x4 conversion. Needs a few things but is operational. Ill post a photo once i figure out how.
  #248
Old 09-01-2017, 03:40 PM
Dhenry113's Avatar
Dhenry113
Dhenry113 is offline
I recently purchased a 1968 Young Fire truck on a Ford C900 chassis. It has a 534 in it and runs real good. I need to find a few parts for it so I can get it back on the road. Need a hydraulic clutch line for it. Any ideas where i may get one?
  #249
Old 09-01-2017, 03:55 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1957/80 C series Tilt Cab: The 11 digit VIN begins with C .. But it might be a good idea to post the VIN to make sure that's what the chassis is.
How long is the hydraulic clutch (from master to slave cylinder) line?
  #250
Old 09-02-2017, 06:33 AM
Dhenry113's Avatar
Dhenry113
line
Ii have not removed the old line yet. I can post the measurements once I get it out.
  #251
Old 10-01-2017, 09:05 PM
Big Popie's Avatar
Big Popie
Big Popie is offline
Decode help / Numbers Dummy
Can you help me with this one.
Thankz Big
  #252
Old 10-05-2017, 09:15 PM
Big Popie's Avatar
Big Popie
This is what she was when I found her.
  #253
Old 10-05-2017, 09:35 PM
roKWiz's Avatar
roKWiz
roKWiz is offline
Big Popie, nice C camper there.
A little long in the overhang but. Do you guys have a legal overhanging length ? Down here max is 60% of the wheelbase.
Should be a nice resto, are you planning on keeping the camper or doing something else with it ? Geoff
  #254
Old 10-05-2017, 09:53 PM
Big Popie's Avatar
Big Popie
Well on the Utah DOT page it says ( 6' rear overhang )
As to the second part of your question .
  #255
Old 10-05-2017, 10:28 PM
roKWiz's Avatar
roKWiz
roKWiz is offline
Did look a little longer than 6 foot. Are you going flatbed or another camper ?
Quick Reply: Looking for other C series owners
