Door handle woes...
Old Jan 5, 2010 | 07:30 AM
ramrod7373's Avatar
ramrod7373
I did get it at the local Ford dealer. It is a pretty straight forward fix.
Old Jan 5, 2010 | 04:11 PM
offrdmania's Avatar
offrdmania
All I did was took some simple green and a tooth brush to the entire mechanism first. This cleaned off all of the gunk that had accumulated over time. I then took a little bearing grease and covered the edges of the spring and at the pivot points of the mechanism. 3rd, I sprayed white lithium grease down the cable housing. I pulled up on the handle about 30 times to work in the grease. I did the same on the catch mechanism down lower on the door. Now I can pull the handle up with my pinky finger, no effort at all.
Old Jan 5, 2010 | 07:11 PM
helifixer's Avatar
helifixer
Originally Posted by jeep1947
FARM, check NAPA one of the parts houses can't remember which one having a brain fart but there is a metal one to replace the plastic ones that break all the time. Jeep
this is almost funny, I try to get the plastic ones as the metal ones don't last the cowboys more than a few months.
Old Jan 5, 2010 | 07:27 PM
rodneywar's Avatar
rodneywar
The cables will cut into the housing making it hard to open the door. I got lucky and the wind bent the crap outta my door so i went to the junk yard and got a new door off a 150 and replaced it. There was a groove in the cable housing on the old door. I snapped 4 door handles.
