76 body question
Old Jan 3, 2010 | 09:01 PM
fire521's Avatar
fire521
76 body question
it has probably been asked before but i couldnt find it, i have a 76 f250 will any 73-79 cab fit this f250 frame? my cab is rusted and was wanting to swap a 2wd body onto it, thanks
Old Jan 3, 2010 | 09:08 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
there are several different frames under each class of truck, in different years....some frames are wider than others at the rear of the cab, the front four mounts are the same but the rears are where the differences are...so measure the distance between your rear cab mounts and find a cab that matches that...look at the placement of the mounts too, some have brackets outside the frame, some sit on crossmembers between the frame....
Old Jan 3, 2010 | 09:27 PM
highboyman's Avatar
highboyman
When we put a 2 wheel drive 79 cab on my 73 f250 4x4 frame the 79 cab had plugs covering the outer holes we just had to drill the holes thru the lower part of the cab. hope this helps.
Old Jan 3, 2010 | 11:32 PM
fire521's Avatar
fire521
thanks that is a big help
Andrew76
Feb 17, 2014 02:03 PM
Customcab
Apr 2, 2008 08:48 PM
towtruck1
Aug 9, 2006 08:01 PM
oldblue31
Jun 10, 2004 09:10 PM
