1978 - 1996 Big Bronco
96 Bronco ratching sound
Old Jan 3, 2010 | 06:09 PM
jacksbronco's Avatar
jacksbronco
I put this question in wrong spot yesterday.I have a 96 Bronco that when I lock in the hubs and do not put it in 4x4 I hear a ratcheting sound from the right front.If I put it in 4x4 it goes away.Also if I put the hubs in free wheeling it stops.I replaced the warn lockout hubs with new ones still the same problem.Any suggestion
Old Jan 3, 2010 | 07:57 PM
deadeyedevon's Avatar
deadeyedevon
same problem in 2wd?
Old Jan 3, 2010 | 08:04 PM
jacksbronco
When Bronco is in 2 wheel drive there is no ratcheting sound
Old Jan 3, 2010 | 08:07 PM
deadeyedevon
im thinking front u joint, does it do it when turning in one direction or another?
Old Jan 3, 2010 | 08:11 PM
jacksbronco
When I am moving forward
Old Jan 3, 2010 | 08:16 PM
deadeyedevon
i would let this post marinate a bit, im thinking u joint but it could be something else.so may possibilities, you did right with swapping hubs,that will help narrow it down.
Old Jan 3, 2010 | 08:23 PM
jacksbronco
Thank you for your help.I had put the locking hubs on for 2 days then the ratcheting started.
Old Jan 3, 2010 | 09:19 PM
helirich's Avatar
helirich
I suspect the u-joint also. How about jacking the front up and spin it by hand. You can probubly see/hear better. You might tear that hub back apart and see if all is ok.
Old Jan 4, 2010 | 11:32 AM
Encho's Avatar
Encho
The Southernmost Mod
Do what Heli said, you might be able to isolate the source of the "ratcheting", if nothing else, try greasing everything to see if the noise goes away (did you grease the hubs when you mounted them?, they need some grease, don't just fill up the thing).
Old Jan 4, 2010 | 06:35 PM
jacksbronco
Yes I did greese the new hubs.I will try tomorrow to jack up the Bronco and see if I hear anything.
Old Jan 4, 2010 | 06:39 PM
deadeyedevon
let us know what you find out
Old Jan 5, 2010 | 09:09 PM
jacksbronco
ratcheting sound
Well I changed the front 2 u joints and it solved the problem.It looked like the original u joints.140000 miles not bad for Ford parts.Thanks for all the help.
