Sponsored by: Real Truck
Truck lunges when engine is started
Old Jan 3, 2010 | 02:32 PM
VAXB's Avatar
VAXB
Ok, I have an 03 F250 auto with the V10. when I start the engine the truck makes a forward movment, then seems to settle back. The truck seems to run and shift fine otherwise. Any suggstions? Is this a hint of troubles to come?
Old Jan 3, 2010 | 03:28 PM
ReAX's Avatar
ReAX
I've never heard of it working quite like that. High line pressure in the transmission can cause a lurch or jump when shifting into drive. A lurch while starting sounds like the transmission is spinning forward when it should be locked in park. I would suggest trying to start the truck in neutral to see if it changes anything.
Old Jan 3, 2010 | 03:52 PM
SuperDutyScaler's Avatar
SuperDutyScaler
my 04 does the same thing, especially when its real cold outside. i just turned 72 k and the truck is still fine so i never bothered with it.
Old Jan 3, 2010 | 04:28 PM
Rongold's Avatar
Rongold
Talking
My 03 F-250 5.4L has done that since the day I got it---So far, no problems !!!
RON
Old Jan 3, 2010 | 04:42 PM
suzuki0702's Avatar
suzuki0702
same here...no problems!
Old Jan 3, 2010 | 06:14 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Yeah, I've noticed mine do that a time or two. Ditto on it happening on cold mornings.
Old Jan 3, 2010 | 06:40 PM
VAXB's Avatar
VAXB
well, it has been cold the last few weeks(15 low 30-40's for high). I will try the neutral start in the morning. Good to know i'm not the only one and it doesn't sound like its gonna fall out anytime soon. Thanks for info.
narrowfarm
Mar 20, 2017 11:06 AM
elemint
2015 - 2020 F150
Dec 26, 2016 04:18 PM
Adamre
Aug 15, 2016 06:47 AM
skidley
Aug 17, 2015 06:24 PM
rickfordowner3579
2009 - 2014 F150
May 1, 2014 05:37 PM
