top speed 60mph
Old Feb 17, 2000 | 10:52 PM
StockMan's Avatar
StockMan
top speed 60mph
Many trucks did have 4.11, but don't forget about 4.56's; that was the only factory gearing available in many early 4wd's and it is common in the I-6 trucks too. My 66 has 4.56 gearing in it. I have had no problem hitting 75 with my recent rebuild in that truck. I haven't put a tach on it, but I don't feel the motor is "screaming" either. There is definately room on the pedal too.
<font color="#f80732" size="4" face="Graphite Light">Stock Man
</font><font color="#0000FF" size="2" face="Graphite Light">1967 F-250 FE 390 4wd</font>
<font color="#0000FF" size="2" face="Graphite Light">1966 F-250 I6 240 2wd LWB Flare Side</font>
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Feb 17, 2000 | 11:29 PM
BigBrownTruck's Avatar
BigBrownTruck
top speed 60mph
Well one won't go at all with no engine. When it had the 302, it went over 80 but I was pushing the motor and although I had an Edelbrock Carb/manifold, there wasn't anything special about the rest of the motor. The 69 I'm not sure I'd want over 80 because of vibration. It is kinda nerve racking at that speed. I think I may have an ignition problem related to bad wiring and perhaps crossfireing, I got a little freaked the other night when it missed a 3000 Rpm. Either that or I heard a valve collide with a piston, I'm not sure. That motor needs a shortblock rebuild so it's biding it's time until I get the Brown Truck running. I'd like to try a higher ratio with the 390 when it is healthy.
Anyway I've feel that ignition/advance/small engine has held one truck back, and ignition/wore out running gear/tired engine have held the other one back.
BBT
ICareyNoCash
Mar 1, 2016 09:01 AM
Millam
Feb 26, 2016 11:45 AM
tinman52
Nov 9, 2015 09:45 AM
ncranchero
North Carolina Chapter
Jan 20, 2015 04:08 AM
sparky69
Offroad & 4x4
Dec 26, 2005 07:23 PM
