Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
02 escape
Old Jan 3, 2010 | 11:50 AM
jonboko's Avatar
jonboko
02 escape
Have 02 escape starts fine everyday if it sits for half hour or so it cranks strong but doesnt catch for awhile,did notice if you push gas pedal it starts ok.It only does this after you shut it off and go into store etc. for half to 45 mins ,if you are in there for hour and a half it starts fine.Replaced gas filter and iac. Any ideas out there ?
Old Jan 3, 2010 | 12:08 PM
wptski's Avatar
wptski
Sounds like something to do with temperature, engine coolant temperature or air intake temperature.
Old Jan 6, 2010 | 05:40 AM
jonboko's Avatar
jonboko
02 escape
what might a remedy be for these issues?
Old Jan 6, 2010 | 05:46 AM
skibender's Avatar
skibender
Bill - are you thinking that the PCM is getting the incorrect reading from one of the above? Then not properly compensating for the correct temp during his restart?
Old Jan 6, 2010 | 08:53 AM
wptski's Avatar
wptski
Yes and the only way to check this is with a scanner looking at those PIDs.
Old Jan 6, 2010 | 02:18 PM
jonboko's Avatar
jonboko
hooked up scanner (actron) everything checks out a ok
Old Jan 6, 2010 | 02:20 PM
jonboko's Avatar
jonboko
.Also just cleaned maf sensor and throttle body.It just does this once and awhile other wise runs and drives like new ,vac hoses ok,no manifold leaks 79,000k 3.0 v6
Old Jan 6, 2010 | 05:58 PM
wptski's Avatar
wptski
There was a owner that had a vacuum leak from the lower gaskets that only acted up when cold. Yours might be a similiar issue.
Try spraying some "Quik Start" around the gasket areas to see if your idle changes.
Old Jan 6, 2010 | 11:49 PM
bmuhlbach's Avatar
bmuhlbach
take iac valve out and look at passage and look at the iac for any issues .This sounds the same as what mine did it was the iac on mine
bow66
Jul 30, 2013 06:04 PM
wswinyer
Dec 31, 2012 02:16 PM
teardropty
Nov 2, 2011 12:56 PM
thewest2
Dec 28, 2010 05:52 PM
seevee
Aug 18, 2007 02:11 PM
