Drum to Disk
Old Feb 19, 2000 | 08:29 AM
StockMan's Avatar
StockMan
Drum to Disk
Old Feb 19, 2000 | 11:07 AM
Elkman's Avatar
Elkman
Drum to Disk
I want to put disk brakes on my 68' F100 2WD. In a few weeks I will be replacing my 352 with a 390 and adding p/s and a C6 trans. Is there a kit I can purchase to do the brake conversion? I need to replace the king pins, front springs, shocks and bushings anyway.
Thanks
Old Feb 19, 2000 | 11:26 AM
390fe's Avatar
390fe
Drum to Disk
There's a well written article on a drum to disc conversion right here on the FTE home page. You'll find the article under the link for Technical Articles.
Old Feb 19, 2000 | 12:56 PM
jowilker's Avatar
jowilker
Drum to Disk
Elkman, I strongly urge you to purchase a donor 75-79 harvest and use the I-beams, steering gear, steering column, brake booster, part. valve, and make all the conversion at one time.
You can change out the I-beams with less work than changing parts.
Don't get rid of the donor until you are up and running and happy with the setup.
Good luck,
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
