bed removal
Old Jan 5, 2000 | 10:05 AM
jbhf250's Avatar
jbhf250
bed removal
Old Feb 19, 2000 | 04:57 AM
250two_by's Avatar
250two_by
bed removal
I'm going to remove the rusted out box on the '77 f250 and was wondering if it's as easy as it looks. Remove tailights, gas tank filler pipes.(two with the 460 of course). Can I just grind off the heads of the bolts from inside the box and then lift the whole thing off with a chainfall? I'm planning on making it a shorty with a custom wood flatbed.
Old Feb 19, 2000 | 08:29 AM
StockMan's Avatar
StockMan
bed removal
<font color="#f80732" size="4" face="Graphite Light">Stock Man
</font><font color="#0000FF" size="2" face="Graphite Light">1967 F-250 FE 390 4wd</font>
<font color="#0000FF" size="2" face="Graphite Light">1966 F-250 I6 240 2wd LWB Flare Side</font>
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Feb 19, 2000 | 09:39 AM
jowilker's Avatar
jowilker
bed removal
250, there are 8 bolts holding the bed on, 6 through the floor, and 2 at the back frame member.
I have taken them off by myself, without a chain hoist. Just lift it up and roll it off to the side.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Feb 19, 2000 | 06:33 PM
oleblue70's Avatar
oleblue70
bed removal
if the bed has been on for along time you have no other choice than to grind.the carriage bolts will turn in the bed if rusted or to tight and they are a joke to torch off underneath.those bolts are high-tensile.some beds won't even come off w\ the heads grinded off!the shank is bigger than the threaded hole,so you can't push them through.blue=
Old Feb 19, 2000 | 06:39 PM
250two_by's Avatar
250two_by
bed removal
Thanks ......
Old Feb 19, 2000 | 07:45 PM
GWB's Avatar
GWB
bed removal
Myself I chuck up a drill bit in my drill and drill app. 3/8 of and inch into the head of bolt, they simply fall out when done. If it spins take vice grips to the nut. Drill same size of shank of bolt. Just my 2 cents
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
