OK well the tranny in my truck is gone. i was wondering if any body out there has converted a 79 F-100 to a stick shift. Im planning on either swapping in a 4 speed w/OD or a 4 speed granny low. is there any little tricks that i need to know? like what parts i will need and such. Thanks for any information.
BR, you bees looking at a project, tis a heck of a lot easier to change from man. to auto than the other way round. Adding clutch, linkage, peddles, changing the column is a lot tinkering. I'd rebuild the tranny and save the headach.
If you must, find a donor and get your tranny, and all the parts from the same unit and use them as a guide.
And make sure to be in the same engine family, for proper boltup to the engine.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
