turbo boost question
Old Jan 2, 2010 | 02:47 PM
going up 2!'s Avatar
going up 2!
i just had my 05 psd at the dealership for a turbo cleaning.when i called to check on status they said they had turbo off and tech was "sandblasting"it.ive read the tech article on here and was wondering if sandblasting was a normal practice?also since the truck was returnred it seems to be lower on boost.im only using factory boost gaude so i know its not exactly accurate but it always seemed to be around 27-30 psi before service but now it stops at 20 psi every time.thanx for any info.
Old Jan 2, 2010 | 03:05 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Maybe you also got the new flash, IIRC some guys were saying their boost was lower after the flash. I'd call them Mon and express your concern and see what they say.
Old Jan 2, 2010 | 05:12 PM
cheezit's Avatar
cheezit
as long as they didnt sand blast the impeller orcompressor wheels it fine. I wish we had one
Old Jan 7, 2010 | 08:35 AM
going up 2!
so i spoke to the dealer about my boost issue and the tech told me anything over 20lbs was normal which i thought was a little vague.when i told him it was originaly around 29lbs he looked at me as if i had 3 heads.off to the dealership it goes again monday.
Old Jan 7, 2010 | 09:02 AM
69cj's Avatar
69cj
29 is pushing the outside limits. Everyone I know with a 6.0 are usually between 22 and 26 with a load. Our boost gauges are pretty acccurate the sweep could have been expanded however for more accurate reading.
Old Jan 11, 2010 | 11:08 AM
chas111's Avatar
chas111
What is usual turbo boost when driving 65-70mph, unloaded?
Old Jan 11, 2010 | 11:45 AM
ljutic ss's Avatar
ljutic ss
On level ground, 5-7 lb's of boost.
Old Jan 11, 2010 | 12:23 PM
chas111's Avatar
chas111
I recently took trip up north with -20 temps and had some issues with fuel gelling. I noticed my turbo boost is running a full 10 now when on interstate (level ground). I have a new fuel filter set to change (I am due anyway). I don't remember the boost being that high before - I think that is why it seemed out of the ordinary.
Old Jan 11, 2010 | 02:38 PM
jmaskew's Avatar
jmaskew
Just a thought... is the egr valve unplugged? An unplugged egr valve will have less boost with higher rpm's and more boost in the lower rpm's.
Old Jan 11, 2010 | 04:39 PM
chas111's Avatar
chas111
I have not tinkered with EGR so it should be ok.
Old Jan 11, 2010 | 11:05 PM
dieselsmoker's Avatar
dieselsmoker
ive seen 28 psi boost with my 06 f-350 and ive seen 35 psi when it was really cold -35 with a 70 km/h wind so like -50
Old Jan 11, 2010 | 11:08 PM
tex25025's Avatar
tex25025
That would help explain your headgasket problems.
Old Jan 11, 2010 | 11:12 PM
dieselsmoker
tex wat would cause it to boost up that high to 35psi , and as soon as i seen it boost that high i backed out of it right away
Old Jan 11, 2010 | 11:19 PM
tex25025's Avatar
tex25025
Vanes sticking could do it, which would relate to an EGR system concern.
If you are running a programmer(particular a heavy ad brand like Banks, Edge, BullyDog etc), those have been known to cause overboost conditions such as that. Even some SCT programs from certain tuners(people) have been known to cause high boost numbers, it just depends on what they did in their programming.
Even having the tuner could cause the vanes to stick as well and there you have an overboost(that's what I would call an overboost anyway, it may not trigger the actual DTC saying overboost condition).
Old Jan 11, 2010 | 11:25 PM
dieselsmoker
ive read on hear u dont wanna go over 26-28 psi boost but one thing on the new truck 05 and up the factory boost gauge has a red area that goes from 35psi to 40psi so most people would think 35psi was on the edge of acceptable boost pressure.
