Update on leaky injector
Old Jan 1, 2010 | 10:15 PM
Rick Wallace's Avatar
Rick Wallace
Good news,I think..I pulled the injector out,could not find any evidence of a copper washer in the hole,[is their a trick to that?] so I put the injector back in and the leak was gone.I still have a start problem when the engine is hot,Cold it will fire the first few turns,after it gets good and warm it wont start and the fuel filter is almost empty.Maybe air in the fuel system?
Old Jan 1, 2010 | 10:22 PM
starmilt's Avatar
starmilt
That is backwards does it run good can you hold it at full throttle in high gear for a little ways without it missing.
rupejosh's Avatar
rupejosh
ooh as far as the fuel filter not being full thats air intrusion.heres the bad news the not wanting to start when warm is a good indicator your IP is going bad
Old Jan 1, 2010 | 10:29 PM
Rick Wallace
It runs great,I just went through putting a new IP on it,Pete talked me through that job.It was rough on me till I figured it out, I had this start problem 5or6 years ago then it just went away
Old Jan 1, 2010 | 10:40 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Sounds like time to replace the return lines and O rings at each injector.
Air is leaking in letting the fuel return to the tank from the fuel filter.
Usually that problem is worse when the engine has been sitting a while.
Old Jan 1, 2010 | 10:46 PM
rupejosh's Avatar
rupejosh
maybe the heat from the motor is expanding the lines and the clamps are loosing their clamping pressure?
Old Jan 1, 2010 | 10:51 PM
Rick Wallace
It sat for about 6 weeks while I saved $$ for a new IP, then it turned off cold[for here anyway] what is that doohickey on the fuel filter bracket that looks like an air valve sticking out?
Old Jan 1, 2010 | 10:53 PM
rupejosh's Avatar
rupejosh
thats the schraeder valve you can test your fuel pressure there if you depress the needle in there while running or cranking it will(should) spit out a good majority of fuel
Old Jan 1, 2010 | 10:59 PM
Rick Wallace
Come to think of it,I have never had any problems with the truck unless it was winter.How much pressure should it have?
Old Jan 1, 2010 | 11:00 PM
87crewdually's Avatar
87crewdually
Another place air can get in your system. I always cap mine in case that valve leaks.
Old Jan 2, 2010 | 06:42 PM
Rick Wallace
Ok, so if its air intrusion would it leak fuel at the air leak or not nessicarily?
Old Jan 2, 2010 | 06:48 PM
rupejosh's Avatar
rupejosh
if air is leaking in doesnt mean fuel will leak out.air is thinner than fuel so if its not air tight it could be letting air in.
Old Jan 2, 2010 | 06:52 PM
Rick Wallace
Talking
Alrighty then,I think I know what ill do,if my sweet darling boss will let me get a return line kit,ill try that.I was thinking the set on there was almost new,but according to my records its about 7 years old. I have a terrible memory.
Old Jan 2, 2010 | 06:57 PM
rupejosh's Avatar
rupejosh
remember to use vaseline on the injectors before you snap the caps on
Old Jan 2, 2010 | 08:29 PM
starmilt's Avatar
starmilt
Rick it can leak air with out leaking fuel air moleculesare smaller the reason an air leak is hard to pinpoint sometimes.
