1978 - 1996 Big Bronco
C6 Valve Body Help??
Old Jan 1, 2010 | 07:59 PM
floridamudder88's Avatar
floridamudder88
I rencently did a tranny swap in my 88 Bronco to a 1986 C6 transmission. It has an aftermarket full manual reverse valve body in it(shift pattern PRN123). The tranny ran fine so I decided to take it wheeling and it tested fine. The problem is now whenever I try to shift down to second gear, the whole truck comes to a stop. My RPMs stay the same, but feels liek I'm slamming on the brakes. I called a local tranny and shop and he said it sounded like something binding in the valve body..does anyone know what this could be? I'd appreciate any help, I really don't wanna dump $200 for a new valve body..
Old Jan 1, 2010 | 10:37 PM
alxsnmr's Avatar
alxsnmr
You may want to check with the trans forum. You can also drop it out and work on the Valve body yourself as it isn't extremely complicated...
Old Jan 2, 2010 | 07:57 PM
floridamudder88
I didn't know there was a trans forum, thanks for the info:]
I'll try my luck there.
Old Jan 4, 2010 | 02:09 PM
alxsnmr's Avatar
alxsnmr
Just as a thought, have you checked your second gear servo? if it gets cocked in the bore it wont engage the band properly. It is easy to get to as it is on the right hand side just above the trans pan as long as the exhaust pipe isnt in the way. Though it may readily leak fluid if you take it off without draining the trans first.
Old Jan 4, 2010 | 04:17 PM
floridamudder88
No, I'm sort of new to working on transmissions haha. I know where it is, but how would I go about checking it? Would I just retorque it?
Old Jan 4, 2010 | 05:37 PM
floridamudder88
Another thing, I called a transmission shop and he said it could be the torque converter, would it locking up be a symptom of a bad converter? He said something about how first and reverse would work because there's not that much torque, but 2nd gear as more torque, so that's why it's locking up.
Old Jan 4, 2010 | 07:19 PM
helirich's Avatar
helirich
There is nothing I can think of on the torque converter that would cause the wheels to lock and not effect the engine rpms.
Old Jan 4, 2010 | 09:46 PM
floridamudder88
It doesn't feel like the wheels are locking up, just the tranny. Sorry, I should've specified in the thread.
Old Jan 5, 2010 | 07:48 AM
alxsnmr's Avatar
alxsnmr
Like Helirich said there isnt anything in the torque converter that would lock up unless there is trash inside of it that is locking the vanes up.
The servo has to be removed from the case to check for the piston being cocked/stuck in the bore of the cup it sits in.
Old Jan 5, 2010 | 09:05 AM
floridamudder88
Ok, I'll check the servo today and let eveyone know what's up. Thanks, I appriciate the help:]
BigSexy78
Jun 13, 2017 08:16 PM
Borolf
Apr 11, 2017 08:13 PM
wyazel1
15
Apr 7, 2017 11:36 AM
tym64
1983 - 2012 Ranger & B-Series
Oct 9, 2016 10:08 AM
jas88
Aug 18, 2016 03:13 PM
