strange brake problem
Thanks
Happy New Year!!!
Chris
when i loose the pedal while hitting a bump im pretty sure that's been over ten mph.
I have never noticed the light come..
In 2wd,,the front will lockup easier in slick conditions(I found this out yesterday) while the rears anti-locks chatter away,,In 4x4 atleast the front and rear are locked together,and it helps braking and turning,,and the fronts wont lock-up as easy,,,unless you really jump on the Binders!,,,I have studded tires too,,,and slid like on wet Ice!
Now I recently did my rear Brakes,,,slides pins were all nice and lubed,,moved well,,,RR cailiper froze up after, compressing the 2 caliper pistons in and replacing pads,,,the RR brake was smoking after just a short drive,,,Replaced Caliper,,,rear brakes stay cool now,,,I am just going to replace the front caliper's too,,,maybe I will pickup a 1-2 mpg,,with out the front brakes dragging so much,,,,Ha,Ha,,wishful thinking!!
PS,,The reason I am going to just replace the front calipers is,,,I did both rear brakes,,,I had to replace 50% of the calipers I removed from the rear,,lol,,,I just wanna do the fronts one time,,and be done!
