Connecticut Chapter Join Chapter, Leader:
January B/S thread
Old Jan 12, 2010 | 06:50 AM
  #286
BIGKEN's Avatar
BIGKEN
Good morning CT!!!
Old Jan 12, 2010 | 03:46 PM
  #287
Aerocell4x4's Avatar
Aerocell4x4
Diesel Van Enthusiast
Good evening everyone.
Old Jan 12, 2010 | 06:07 PM
  #288
BIGKEN's Avatar
BIGKEN
Howdy Dave!!!
Old Jan 12, 2010 | 06:39 PM
  #289
Nice Work Truck's Avatar
Nice Work Truck
Hi Dave, Ken, and all the rest.
Old Jan 12, 2010 | 07:35 PM
  #290
Aerocell4x4
Hi there Ken & Andy.
Another boring day here at 'work.'
Old Jan 12, 2010 | 07:37 PM
  #291
BIGKEN's Avatar
BIGKEN
Howdy Andy!!!
Old Jan 12, 2010 | 08:14 PM
  #292
IrnRngr's Avatar
IrnRngr
Good night, good Ford people.
Old Jan 12, 2010 | 08:17 PM
  #293
rtcalabrojr's Avatar
rtcalabrojr
Darksider
Hi Dave,Ken and Andy
I know this is off topic but anyone have ideads on what could cause a drain on the truck. Its a 01 Dod#E, the only added option to the truck is an alarm with remote start. This has been in there for years!! Everything works like it should. Do you guys think think that the alarm is killing the battery? I was going to try to unhook it this weekend and see if thats it but any help would be GREAT>
Old Jan 12, 2010 | 08:21 PM
  #294
Aerocell4x4
Hi Roger
Could be a bad battery, a cell is no longer holding its charge.
Old Jan 12, 2010 | 08:51 PM
  #295
rtcalabrojr
Darksider
replaced with new battery and alt.
Old Jan 12, 2010 | 09:01 PM
  #296
7.3 Rocket's Avatar
7.3 Rocket
If you can't find the drain you can always put an electric disconnect on it.
Old Jan 12, 2010 | 09:11 PM
  #297
Aerocell4x4
Put an amp meter on between the battery post and its cable, see what if any current flow you have.
Then pull every fuse and see what there is for current.
Then start replacing the fuses, see if there is an eureka or just a general increase in current flow.
Might be able to narrow it down to a circuit or two.
Then again your wiring system may have many leaks to ground like a sieve.
You could also have mung over the hot side of the starter solenoid terminal and that is draining your battery.
Old Jan 12, 2010 | 09:15 PM
  #298
Aerocell4x4
Another sneaky one is the engine compartment light switch being stuck 'on.'
You wouldn't notice that so much because you have the hood up while working on the truck.
Pull the light bulb and see if the battery holds its charge.
Old Jan 12, 2010 | 09:24 PM
  #299
rtcalabrojr
Darksider
Thanks Dave!!!! I will be looking at the truck sat morn.
Old Jan 12, 2010 | 09:30 PM
  #300
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Good Evening CT....
