powertrain control module problem
Old Dec 31, 2009 | 04:20 PM
tfsconst's Avatar
tfsconst
I seem to be having a problem,when i plug in my superchip scanner and go through the motions it calls for me to tune or diagnostics i click diagnostics then it comes back with NO RESPONSE on the screen
i have also tried it on another truck and it works
also it seems that the relay for the injector module in the fuse box chatters all the time when the switch is on
does anyone have any ideas
Old Dec 31, 2009 | 04:29 PM
cps's Avatar
cps
What other truck did you try it on because not all scanners will work on these trucks.
Old Dec 31, 2009 | 04:37 PM
tfsconst's Avatar
tfsconst
im sorry i didint tell what kind of truck i am working on.It a 02 250 crewcab 4x4 with 7.3 powerstroke diesel and the other truck it worked on was my brothers and it is a twin we bought them new together
Old Dec 31, 2009 | 04:42 PM
SpringerPop's Avatar
SpringerPop
What's your battery voltage?
You should be able to pull the IDM relay and the PCM will still function. Of course, the engine won't run without the IDM. But the PCM should still be normal.
Chattering relays usually indicate a low voltage condition.
Pop
Old Dec 31, 2009 | 05:03 PM
tfsconst's Avatar
tfsconst
my voltage appears to be 12v the truck turns over well,but it wont start
Old Dec 31, 2009 | 05:05 PM
tfsconst's Avatar
tfsconst
also i have pulled the relay and replaced with another an it still chatters
Old Dec 31, 2009 | 05:16 PM
CPUNeck's Avatar
CPUNeck
Does your cigar lighter work? May just be no voltage to the ODB-II connector.
Old Dec 31, 2009 | 05:27 PM
tfsconst's Avatar
tfsconst
yes and all the fuses have been cheked with a test light
Rusty Axlerod
Nov 5, 2015 04:29 PM
ejaba
Jan 19, 2015 09:34 AM
Traildust
May 18, 2014 03:48 PM
350Lariat
Dec 1, 2013 06:30 PM
beeshoo
Apr 15, 2007 01:52 PM
