Sponsored by: Real Truck
F450 Light Mod?
Old Dec 31, 2009 | 06:19 AM
Chrisb009's Avatar
Chrisb009
4wd High
F450 Light Mod?
I have the 08 F450. I am wondering if there is a light mod for the F450 that turn on all lights when brights is applied. There is a mod for the Silverados which simply uses diodes between posts to turn all lights on when brights is applied. I searched the board and came up empty. Anyone have any idea?
Thanks,
Chris
Old Dec 31, 2009 | 10:59 AM
mhoefer's Avatar
mhoefer
There is a mod you can use to have your driving lights come on with high beam, instead of low, but you cant run low and high beams, and driving lights as I understand it. I have never bothered, probably better way to go is slighlty higher wattage low and high beam bulbs and higher wattage driving light bulb. The only problem with this is how well the harness holds up to the extra wattage..
Old Dec 31, 2009 | 11:17 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
You want a bright box!
Riffraff Diesel: The Brite Box™
