Help! - Rust on frame - Need advice
Old Dec 30, 2009 | 11:45 PM
lmd91343's Avatar
lmd91343
I need a little help. I have some rust on the frame of my '89 F150.
In some sections of the frame, I noticed a bit of rust. It is not very deep or thick. It could be sanded off with a couple of passes of 1500 grit sand paper. Maybe 5-10% of the frame has this light spotted rust.
I don't want to do an off the frame restoration. I can't easily reach most of the rust spots to work on directly. Is there something I can do? I don't want the rust monster to get a foothold. Does the Eastwood Encapsulator or the POR-15 product work? There are the usual fuel lines, exhaust, brake lines, electrical looms, and an additional electrical loom underneath.
I have a bad back and twisting, contortions, and heavy work are beyond me. I need an easy approach.
My truck has been a Los Angeles car for its entire life, the warm dry part of LA. It has never been near the beach or snow and salt country. The body is just about perfect., no dents, scrapes, or rust, only one "keying mark". I've done a conversion to SEFI MAF, changed the intake a bit, had custom leather bucket seats made, replace or repainted all the interior parts, and many other improvements. The truck is very nice and I want to keep it.
Thank you!
Old Dec 31, 2009 | 07:10 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Physically I am in the same shape so I know what you're dealing with. Eastwoods Rust Converter, followed by Rust Encapsulator, then Extreme Chassis black is what I used on my ground up resto. You can brush the converter directly over the rust and the encapsulator also comes in a spray can for those hard to reach places. I'm real pleased with results.
Edit: Actually I believe the converter is made by SEM so should be able to pick up at local auto paint supply.
Old Jan 1, 2010 | 03:41 PM
lmd91343's Avatar
lmd91343
I'll go that route.
Thank you
Old Jan 1, 2010 | 09:34 PM
craftsmangary's Avatar
craftsmangary
POR-15 a goo product, I used it on my frame and was very happy with the results, just follow the directions and do not! get it on your skin
Old Jan 2, 2010 | 09:32 AM
Sand_Man's Avatar
Sand_Man
Another vote for POR-15 here...
Old Jan 5, 2010 | 09:05 PM
e-tek's Avatar
e-tek
I'm a TOTAL POR-15 fanatic. Wear gloves and brush it on. Store the balance in a glass jar with plastic between top and jar, will last for a long time. One step and it's done - forever!
kenb6656
15
Oct 20, 2012 05:15 AM
TxFordGuy
May 26, 2009 11:36 AM
Equestriana
Paint & Bodywork
23
Apr 17, 2008 12:38 AM
58shortbed
Dec 15, 2004 04:46 AM
