Mono Leaf Springs
Quick question about mono leaf springs. I read the post a couple days ago about the gentlemen worried his mono leaf springs were too long. one of the responses to his thread was to get rid of the mono's you won't like them.
My question is what are people finding with the mono's are they not worth the cost? It seemed like a great idea to me until the question of others not liking them was raised. How does everyone like/dislike them? Pros and cons.....
Thanks Jeff
Thanks Jeff
If a mono leaf is such a great idea, why can't I think of a single ( no pun intended ) car manufacture that use's them.
Last one. Many who buy them so they can lower there trucks and cars, from others experience, they don't. I'm sure others will chim in.
I'm sure he will be along soon to expand on his opinion and why he made th ecomment. He is very good about providing factual rational for his comments.
The previous poster that said his mono leaf seemed too long and was bottomed out at the shackle, will have no give at all, and in my opinion, is in danger of breaking something. The whole point of the shackle is to take up the slack as the spring flexes and "grows" as it flattens out. With nowhere to go, something is going to give, somewhere. Given that choice, personally, I'll stay with 'old school'.
A lot of modern european vans eg Renault master use a monoleaf in the rear - the van my work supply for me has this. Looking at the spring the steel is very thick however compared to a normal stack, and it tapers to each end.
Mono Leaf vs. Multi Leaf Springs
There are two types of monos, the tapered leaf type Eaton describes and single thickness (basically just a heavy main leaf). The tapered leaf is especially prone to breaking because the majority of the flexing is done near the ends of the leaf where it's thinner rather than spread equally over the entire length. Think of an archer's longbow (a tapered monoleaf) where does the majority of the bending take place? Would a single thickness bow (spring) work well (most here have likely tried making a bow out of a sapling and a string)?
Along with the safety issue comes the secondary (but still significant) issue of wrap up.
Someone a while back was looking for the reason that drag racing cars would hop and chatter the tires on launch. They originally thought it was due to the tires of the day not holding traction, so they roughened up the starting pad. That made the problem worse. So that thinker decided to film the suspension and tires at high speed and play it back at slow speed to understand what was happening. What they saw was unexpected and very enlightening: indeed the tires were losing traction and regripping, but it was not due to the tires losing surface grip but the leaf springs (remember most cars in the day had parallel leaf springs in the rear) were being forced into a S shape due to the axle torque when the tires were hooked up, until the spring would reach a point where it would overcome the tire's grip and snap the axle rotation back the other way. This would break the tires loose until the spring straightened then the grip would be regained and the cycle would repeat. This revelation cause the invention of "traction bars" and similar devices to control this spring reaction or the spring "wrap up" as it was coined.
Fast forward to monoleafs. GM tried rear Monoleafs on a low end compact dubbed the Chevy II for a short time. This small lightweight inexpensive body/chassis was an immediate hit with the racers during the "gasser wars" and the oncoming altered wheelbase FX cars. But there was a problem! No matter what kind of traction bars were tried, the rear of the spring would still develop the dreaded "spring wrap". The invention and development of ladder bars helped a bit by physically restaining the rotation of the axle rather than trying to control the spring flex, but GM found that the manufacture of the tapered leaf and it's uniform tempering into a spring was problematic and expensive with a lot of rejects, and breakage on the street with the subsequent loss of control started raising it ugly head. The bean counters and legal eagles got together and said NO MORE! and in the next generation of the CII the monoleafs were replaced with coil springs.
FF again to the present: Rear mono wrap up isn't as big a problem on our beloved trucks especially if ladder bars are added, because our extra light a$$ ends and relatively narrow hard tires restricts the amount of axle torque we can develop. But wrap up once again rears it's ugly head with front monos upon braking. Many of us have upgraded our front brakes. When the brakes are applied hard the tire tries to move back and the weight transfer pushes the nose down, rotating the front axle against the spring. With the axle's drop and hanging below the springs the rotating axle has a lot of leverage and easily arches the softer front and rear ends of the mono. Two (or three depending how you count) things happen: 1. the rotation of the axle causes the front geometry to chang not good for control. 2. like the dragracing wrap up problem, the spring reaches a flex point where it overcomes the tire grip and pops the tires forwards breaking traction and causing the front of the truck to "dance around". There is no steering control when the tires have no traction. 2a or 3. the traction between the tires and the road are never equal side to side so this torque hop and is not going to be equal and simultanious side to side, so the axle is also going to rotate around it's centerpoint like the front of a child's wagon, and we all likely know how much steering control that has.
I have heard that you can lower eliminating everyother spring from the original leafs. Has anyone had experince with this? I want to use the original axle and am looking for a way to lower the front and rear. Any ideas?
But currently (01/01/10) there is an 8 week waiting list on truck axles due to demand.
I had a company from California quote $238 to ship a pair of mono springs to me.
It would be interesting to know how much springs and axles weigh for shipping purposes.
Alex
