2002 explorer
Old Dec 30, 2009 | 09:02 PM
joshn569's Avatar
joshn569
2002 explorer
hey. just bought a 02 explorer limited with V8. This truck is loaded to the max, more buttons then i know what to do with. (seriously i dont know what half of them do yet)
It has the buttons for keyless entry but i have no code....... where can I find code or reprogram new code?? i dont have an owners manual.
Is there and online owners man or service manual i can download or view via PDF for free??
thanks
Old Dec 30, 2009 | 09:37 PM
steve(ill)'s Avatar
steve(ill)
open the rear hatch door. remove the plastic cover on the left rear fender well.. look forward a foot or two into the hole. see if there is a sticker on the fender well. you might need a light and mirror to read it. Thats what i found on our 2002.
Old Dec 31, 2009 | 08:05 AM
shorod's Avatar
shorod
Didn't the location on the 2002 move to the passenger side just behind the second-row door? You pull the weatherstripping loose, then pull the plastic trim panel away from the body of the vehicle just enough that you can see the module with a bright light. There will be a white sticker with the 5-digit code in black letters on the module. That 5-digit code is your keyless entry code.
You can access an owner's manual for your truck here.
-Rod
Old Jan 4, 2010 | 06:29 AM
cmaupin's Avatar
cmaupin
-Rod
thanks that is a good post
Old Jan 8, 2010 | 09:30 AM
Moto Mel's Avatar
Moto Mel
thanks
The answer is here; https://www.ford-trucks.com/forums/1...try-codes.html
