Someone Please Explain Tow/Haul
I have a 2014 F450 6.7 w/6 Speed Auto and would like to know what exactly does the Tow/Haul change/do to performance. I used it constantly when towing in my previous F350 and it seemed to affect MPG and engine RPM. The F350 also had an aftermarket engine exhaust brake that I used most all of the time , even when not in Tow/Haul. In the new F450 I don't see any difference other than I can feel the factory exhaust braking when in Tow/Haul mode. Engine RPM stays the same and just driving around with (no load) Tow/Haul turned on my MPG is a constant 13.9, same as with it off.
Other than the exhaust brake, what actually happens when Tow/Haul is turned on? Although it appears nothing happens when I engage it while in motion I'm guessing it changes the transmission shifting programing.
The reason behind the questions is sometimes I commute to my job in the F450 and here in Northern VA traffic is a nightmare and I don't like riding my brakes all the time. So, I turn on Tow/Haul to take advantage of the engine braking and rapid deceleration. Will operating Tow/Haul during routine commuting have a long term detrimental effect on the transmission or drive train?
When towing a trailer or carrying a heavy load, that button will stop the transmission from constantly shifting gears. It will hold a gear longer until the truck is sure it can use the next gear.
I wish we could still get a manual transmission so I can make the choices!
Happy Holidays!
Jim D
I used tow/haul all the time in my '01 and '06 F-250 service bodies with the 5.4L, for the same reasons you're wanting to. I was driving in heavy stop and go traffic in Phoenix, and used the transmission downshifts to help with the braking so I wouldn't have to constantly ride the brakes in grid lock traffic.
It won't hurt a thing.
No, you never used tow/haul in your '01. The first year Ford had tow/haul in ANY of their trucks was 2003. Before that the button was an overdrive cancel. It would just prevent the transmission from shifting to fourth gear.
I would warn that driving in the Tow/Haul mode with an empty truck on a wet road could cause the back wheels to slow down faster than the rest of the truck, especially going down a hill and using the brakes, causing the back to slide. With weight in the bed, that has never been a problem. But I learned that in an empty truck, coming down a hill, approaching a stop sign, at about 30mph while braking, you may need both lanes and the grass to stop it. Oh, and perhaps some clean underwear!
I don't know what a clutch band is, so I can't comment on that. And I do know every part inside the transmission...
"They" don't know what they are talking about. It does not up the hydraulic pressure. There is no reason to up the pressure, the clutches never slip with or without tow/haul.
