Front end issues?
Old Dec 30, 2009 | 02:08 PM
diesel2008's Avatar
diesel2008
Front end issues?
I have a 2000 Expy EB 4WD. When I make a real sharp turn, it feelis like the tire is about to fall off. It drives smooth, no other issues. Is it something I can check to see if it's a problem?
Old Dec 30, 2009 | 03:31 PM
benningstspeed1.0's Avatar
benningstspeed1.0
CHECK THE STEERING IDLER. IT IS LOCATED ON THE RH FRAME.
Old Dec 30, 2009 | 08:10 PM
alloro's Avatar
alloro
Check the ball joints.
Old Dec 31, 2009 | 04:07 PM
dfisherman's Avatar
dfisherman
How many miles on it? Ball joints definately go on these trucks. Replaced mine after about 120K. I could not feel much play in them by jacking the truck up and trying to see if there was slop when I tried to move the tires up and down and left and right, but after I changed them I was surpirsed how much of a difference it made in the steering and handling. Did uppers and lowers. Was not that bad if you are moderately experienced.
Old Jan 1, 2010 | 05:28 PM
alloro's Avatar
alloro
The difficulty also depends on whether it's a 4x4 or a 4x2 because of the front axle shafts.
Old Jan 1, 2010 | 10:37 PM
diesel2008's Avatar
diesel2008
My Expy has 126k. It drives smooth. When I turn sharp to the left, it feel like the tire is going to fall. If I turn to the right, it doesn't do it at all.
Old Jan 2, 2010 | 12:03 PM
EXPY_LUV_R_59's Avatar
EXPY_LUV_R_59
if you want to check the ball joints, you need to take the weight off them. jack it up and put jack stands under each of the front suspension, not the frame, or the wheels, so that when you set it down the ball joints react as if the truck was on the ground. then try rocking the wheels. if they rock they are bad. sometimes when setting down on the jackstands you will actually see them pop out of their sockets a bit.
mvedepo
2009 - 2014 F150
46
Dec 17, 2015 05:48 AM
JAFO1
Nov 18, 2013 02:46 PM
MikeRizz
Sep 20, 2012 06:17 AM
darthice
May 5, 2009 12:49 PM
shiftkx
Sep 15, 2005 11:24 PM
