You are welcome Pops...Hope it works for ya
Make sure when you test drive the truck after the adjusting that the wheel will come back on it's own when you make a turn.
Oh, I will, as soon as this snow clears up, I'll give it a whirl, thanks bud, Happy New Years to you and yours..
Just to add some info in this thread. I had the same slop etc etc etc. New ball joints, new suspesnion ( lift kit) , new tires due to lift, new alignments, new drag links, all made it a little better, but still was slop. Put in a red head steeering box about 5-6K ago and still is awesome! One of the best mods i have ever done. I promise you that will fix your main problem. I think alot don't realize that no matter what we do we will always have some play in these trucks. We do not have rack and pinion, it sthe downsides of a steering box and is a wearable item, so over time it will get worse. Also, right after you put in the red head steering box it will be VERY tight, but after a few hundred miles it will slowly get looser as it bleeds the air out. Don't confuse looser with the same as it was. Red Head people are very nice, and great warranty. And tightening the jam nut will make the steering box tighter, but when you are needing to do that its basically time to change it. It will be a band aid for a while, but thats it.
You are right.I just wanted to get some more miles out of it before buying the redhead.That will be my next step when it get's the slack again.I have heard great things on that unit so it will be installed when needed....Thanks
On mine if you look down from under the hood its in front of the power steering fluid container.You should be able to see the adjuster on top of the steering box.Its an allen wrench.But be advised this will or might make the steering tighter but the play will probably still be there and will only work for a while if it works at all.When I tightened mine it made no difference what so ever.Had to get a red head box replacement.
Locate the allen head bolt and locknut on top of the steering box (close to the radiator). I believe the locknut is 5/8".
Mark the allen bolt so you can tell the orientation that you started from and then loosen the locknut.
Turn the allen bolt clockwise a quarter turn to tighten the gear mesh. Tighten the locknut back up and take her for a spin.
In reading posts by others who have done this, the allen bolt seems to get turned somewhere between three-quarters of one full rotation, and one and one-half full rotation before people are happy with the results. For my Excursion, I tightened mine almost one full rotation before I was happy.
Be careful, because if you over-tighten the nut, the steering may be so tight as to get extremely stiff on a turn, causing you to veer off course.
Repeat the tighten and test drive until you're satisfied with the performance.
If you over tighten, turn back the allen bolt a quarter turn counter clockwise.
There is a risk of over tightening the box and causing it to wear out prematurely, so I tightened it to the point where the slop was gone, and no further.
Stewart
Thanks, I went out to try it but the nut won't move at all. Gonna spray it with some PB and try again tomorrow.
Ok guys keep in mind your messing with the steering here. Get to tight and you will damage your steering box possibly causing lose of steering while driving.........just saying
Yep, that's why the instructions say to use quarter turns, then to test drive your rig to see how it feels. It also gives the reported amounts a lot of guys have rotated their adjustment screw so someone won't go too far on the adjustment. It even gives a warning not to overtighten.
Seeing as these instructions have been around for a few years and there have been a lot of guys using them to get better steering results...well, I guess I'm just saying that the warnings are already included throughout the instructions.
