TAIL LIGHTS DONT' WORK.
Old Mar 4, 2000 | 08:04 PM
ummduh's Avatar
ummduh
Old Mar 5, 2000 | 01:44 PM
OSCAR MONTIEL
Guest
Posts: n/a
I HAVE A 1964 F100. I JUST FINISEHD GETTING THE BODY PUT TOGETHER AND HAD IT PRIMERED. I AM HAVING TROUBLE GETTING THE STOP LIGHTS TO WORK. THERE SEEMS TO BE NO CURRENT COMMING TO THE LIGHTS I HAVE CHECKED THE FUSES AND THEY ARE OK. ANY HELP, WILL BE GREATLY APPRECIATED.
Old Mar 5, 2000 | 02:02 PM
jowilker's Avatar
jowilker
OM if you aint mad, stop shouting with the caps on.
Check at the mastercylinder under the hood. Turn your switch to on, and with a tester check the wires in front of the ms. One should be hot, and the other will become hot when the pedal is depressed. If you have fire there then follow the wire made hot to the rear of the truck and to the bulbs.
Good luck
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Mar 5, 2000 | 02:11 PM
Oscar Montiel
Guest
Posts: n/a
Thanks John!
Sorry, for all caps.
