Cracked Front Cover, How Common?
Old Dec 30, 2009 | 07:04 AM
origcharger's Avatar
origcharger
I have a 2001 model year T444E apart now with a cracked front cover, it was cracked in the oil pump area from about the 1:00 position to the 3:00 position. Symptoms were dying or faltering after starting with warm oil, if it died it we would have to manually fill the HPOP resevoir to get it to go.
It appears to me this crack was generated from flexing caused by the expansion or contraction of the oil cooler as the crack is across the passage leading to the cooler.
Ever seen it? How common? Are certain years more prone?
Old Dec 30, 2009 | 01:18 PM
YellerMax's Avatar
YellerMax
Important HPOP gasket information - Powerstroke Nation
Dunno your truck work history, and doesn't sound like it based on your crack location, but FWIW check this out
Old Dec 30, 2009 | 02:00 PM
bigsteve1969's Avatar
bigsteve1969
i have a front cover i can let go if you need one
Old Dec 30, 2009 | 04:35 PM
F350-6's Avatar
F350-6
Not common at all. Can you post pics? I don't know how much flexing there would be unless some bolts worked loose or the LPOP was worn and moving.
Old Dec 30, 2009 | 07:30 PM
camodown's Avatar
camodown
This is the first front cover I've heard of cracked on a 7.3 PS. Let us know if you find the root cause!
Ford_Guy_68
Mar 9, 2016 06:38 PM
brown89ford
Dec 20, 2014 09:08 PM
devbravo
Feb 24, 2014 09:16 AM
Randy777
Aug 6, 2011 04:52 AM
