1978 awd?
Old Dec 29, 2009 | 06:22 PM
ctblue's Avatar
ctblue
1978 awd?
how hard is it to convert.should i get parts or just change transfer case and put lockouts on it.motor is done and tired of snappin axles
Old Dec 29, 2009 | 09:45 PM
Bgasrickshaw's Avatar
Bgasrickshaw
Hi, and welcome aboard! By "awd" I'm guessing you mean the full time New Process 203 transfer case. Full time 4wd and no locking hubs, right? I believe you can still buy the conversion kits to make them part time 4wd. if you search the site a bit you will be able to find out where to get one. Personally, I like the NP205 part time case better because it is all gear driven and has no chain to stretch or break. It is a very strong transfer case. Probably the strongest stock one you can put in your truck. I had a NP203 with the conversion kit in my '78 Bronco and it exploded just driving down the road in 2wd. Apparently once they are converted they do not get proper oiling to the back end and unless you lock in the hubs frequently to keep that part oiled ( by virtue of the front shaft turning those parts), The dry out and...explode. Search around the site. You will find lots of information and helpful people. P.S. It is customary to introduce yourself to the people on the board when you start posting. Who are ya?
Old Dec 30, 2009 | 08:36 AM
4x4 Bart's Avatar
4x4 Bart
Go with a NP205 they are fairly common and easy to find. The conversions work but are not worth the cost and time to change them over.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
