Electrical mess cont'd
Old Mar 5, 2000 | 06:26 PM
big orange's Avatar
big orange
Hey thanks for the info on the 203, and I just replaced the voltage regulator and all the wires going to and from the alternator and the dumb thing still will not charge. I am really stumped now. I think I am going to get the alt' checked again somewhere else. Any advice will be greatly appreciated.
Old Mar 10, 2000 | 01:58 AM
fordmando's Avatar
fordmando
If you are having this much trouble getting it going, get a one-wire alternator from Summit Racing. Only have to connect it to the battery to make it work.
They are about $100
fordmando
78 F-150 4x4 400 4 on floor
86 Nissan 300ZX
George
<a href=""></a>
Old Mar 10, 2000 | 03:19 AM
BigBrownTruck's Avatar
BigBrownTruck
I put in a GM style one wire alternator made by Powermaster (I think). I have since seen advertised in Mustang Mags a one wire alternator specifically for Fords. Gee my wiring is simpler. The Gm style required that the mounting pivot hole (the bolt into the head) be drilled out from the GM 3/8 size to 7/16. I was told I might have to grind some on my adjustment bracket. I didn't have to. The depth of the alternator is tight. The back of the alternator rests on the head of my 390. I also shimmed out the adjustment bracket from the waterpump with 4-5 washers. I did have to salvage one other wire from the alternator/regulator harness. The big power wire from the body harness needs to be connected to the positive connection of the solenoid. Then the one wire from the alternator to the positive battery cable. I'm happy with the results.
BBT
Old Mar 10, 2000 | 03:21 AM
BigBrownTruck
I meant drilling out the hole in the alternator for the mounting bolt not redrilling the hole in the head.
BBT
Old Mar 10, 2000 | 02:41 PM
63SCtruck's Avatar
63SCtruck
