6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Engine Problem...need help diagnosing
Old Jan 6, 2010 | 04:45 PM
MConstable's Avatar
MConstable
Thanks for all of the advice guys...
Found out today it's HPP failure.
Mother in Law said they have to yank the body off?
I "assume" the HPP is the main fuel pump?
Is it in the fuel tank, and they have to pull the bed to get to it easier?
Old Jan 7, 2010 | 06:18 PM
mhaas59's Avatar
mhaas59
THE CAB AS TO COME OFF TO REPLACE FUEL INJECTOR PUMP. THE PROBLEM IS A SENSOR ON THE PUMP. GO'S BAD YOU CANT JUST REPLACE IT THE HOLE PUMP HAS TO BE REPLACED.MAKE SURE THEY GET THE UPDATED CASKET FOR IT.IF NOT THEY HAVE TO TAKE CAB BACK OFF.HAD MINE DONE THIS IS HOW I KNOW
Old Jan 7, 2010 | 06:25 PM
jboczar's Avatar
jboczar
The high pressure fuel pump is under a cover underneath the exhaust pipes and turbos. If you get a chance check it out when the cab is off, its pretty cool and usually freaks customers out to see their trucks like that.
