b&m shift kit
Old Dec 28, 2009 | 11:41 PM
traxx808's Avatar
traxx808
b&m shift kit
hi guys..........i got a b&m shift improver kit # 40264 for xmas. i have a aode trans 94 f150 2wd 302. has anyone ever had hands on experience with putting one of these in. i would like to know how easy or hard this is before i take on this job. don't want to start it and not be able to finish it. anything electrical in the trans i need to look out for. anything in the valve body i need to look out for. it has 2 stages 1st-rv/heavy duty 2nd-street/strip. don't know which one to go with. would like to use the 2nd setup and was wondering how hard the shifts would be. can i install this with the trans still in the truck. i have a neighbor that has a spare 4r70w valve body. can i use that instead of the aode valve body. this is a daily driven truck. any help on this is appreciated............
Old Dec 29, 2009 | 12:21 AM
zxwut?'s Avatar
zxwut?
It's easy. I like the first stage. I tried the second one on my '66 rustang and it was too rough.
Old Dec 29, 2009 | 04:26 AM
lew52's Avatar
lew52
Its not bad , just follow the instructions . The trans dosn't need to come out . The street / strip set up will shift hard enough to break the tires loose on the second gear shift . When you remove the valve body keep it level , theres alot of check valve ***** that can fall out , when you drill the valve body plate be carfull with the drill bits that come with the kit they break easy , the second gear shift spring is a little hard to hold in while trying to get the clip back in , a small bottle jack helped alot . If you don't already have a trans cooler i would recomend one & a temp gauge to ......Lew
Old Dec 29, 2009 | 05:03 PM
traxx808's Avatar
traxx808
alright guys i will attempt this surgery this weekend after the new year. keep your fingers crossed for me. thanks for the feed back. i was helpful...........
traxx808
Oct 6, 2014 02:42 PM
LARIAT 85
16
Aug 17, 2012 02:25 PM
LARIAT 85
Aug 16, 2012 03:20 AM
Da Mother Ship
Dec 18, 2003 08:51 PM
1rocket
Oct 31, 2002 04:06 PM
