Offroad & 4x4
my winter project
Old Jan 2, 2010 | 06:44 PM
wayfastwhitey187's Avatar
wayfastwhitey187
i put them like that because once the weight get on them theyll swing back a bit right
Old Jan 6, 2010 | 11:25 AM
Prozon's Avatar
Prozon
Hopefully.
How goes the project?
Old Jan 6, 2010 | 02:12 PM
wayfastwhitey187
the suspensions all done but we had to pull it out last night because the old man needed the garage for his race truck so im just gunna build the motor while im waiting for him to get that done
Old Jan 7, 2010 | 10:34 AM
Prozon's Avatar
Prozon
What are you doing with the motor?
Old Jan 8, 2010 | 01:17 PM
wayfastwhitey187
its efi right now so im gunna pull the heads off and put on another set i just redid with new valves and springs and put the intake and everything on it so i can just put it right in. next year im gunna build a motor for it. dont really have the money for it this year
Old Jan 8, 2010 | 03:53 PM
Prozon's Avatar
Prozon
Are you keeping it fuel injected or are you going with a carb?
Old Jan 9, 2010 | 07:59 PM
wayfastwhitey187
gunna switch it over to carb. too many little sensors to mess up. one stupid sensor can make for a real crappy day if it gets wet
Old Jan 10, 2010 | 02:51 AM
Prozon's Avatar
Prozon
I've never had problems with EFI getting wet.. seriously, i've had more problems just sucking up water and mud then actually getting something to wet to work. For the most part any electrical connections can just be greased up and never have a problem.
However, when its something not water... EFI can be a bitch.
Old Jan 10, 2010 | 06:32 PM
wayfastwhitey187
ya ive had problems with my other truck before so i want to avoid that. and besides i plan to build a motor anyways and i cant really do much with an efi set up
Old Jan 11, 2010 | 10:40 AM
Prozon's Avatar
Prozon
You can do a lot with an EFI setup, it will just cost a bit more than with a carb lol.
Old Jan 11, 2010 | 01:48 PM
wayfastwhitey187
haha true but i dont wanna buy all the progammers and all that because with my luck first trip out i'd end up in a hole that looked like a puddle and ends up being over the roof and ruin it all
Old Jan 11, 2010 | 11:47 PM
Prozon's Avatar
Prozon
Di-electric grease and duct tape.
Old Jan 12, 2010 | 02:45 PM
  #28
wayfastwhitey187
that stuff does work wonders but im junt gunna go with the carb set up less to worry about.
Old Jan 12, 2010 | 03:06 PM
  #29
captain p4's Avatar
captain p4
What are the plans for the project?
If a mud truck, then yeah go for the carb setup if you plan to build a performance motor.
But, if you plan to have this thing on any sort of angle offroad I would stick with the EFI setup, like prozon says dielectric grease is your friend!
Old Jan 12, 2010 | 04:17 PM
  #30
wayfastwhitey187
this is gunna be a full out mud truck. im building a motor next winter that'll probably have like 450-500 horse. i plan to someday put rockwells under it someday with tractor tires and a four link set up on air bags or coil overs
