FE Identification
Old Mar 13, 2000 | 06:11 PM
80f3504x4's Avatar
80f3504x4
FE Identification
I found an old FE motor the other day and right behind the alternator is was cast 352. Does this means its a 352 or not. I couldnt find any other ID tags on the engine. Any help would be appreciated.
Old Mar 13, 2000 | 06:23 PM
hammer4714's Avatar
hammer4714
FE Identification
there are several FE blocks stamped 352, check bore and or stroke good luck
Old Mar 13, 2000 | 07:57 PM
390fe's Avatar
390fe
FE Identification
look on the passenger side of the block, just below the deck. You should find a block casting number. Also, look between the center spark plugs on each head for the head casting numbers. You'll probably have to scrape away some gunk. Post your numbers here and I'll try to figure it out. The best way to identify these motors is to measure the bore and stroke. Casting numbers will only get you an educated guess.
Old Mar 13, 2000 | 08:27 PM
GWB's Avatar
GWB
FE Identification
stevejohnson48
Feb 5, 2013 07:39 PM
bwilliams7527
Apr 21, 2008 07:01 AM
FERacing66
37
Jul 11, 2004 01:44 AM
FEProStreetGalaxie
25
Dec 4, 2001 06:39 PM
rod
Oct 7, 1999 08:51 PM
