loud noise amplified through airbox?
#31
OT but.........
It seems to me that if extended idle can cause this to happen, the following may also cause wet stacking:
Starting the engine before the wait light has gone out.
Operating the engine with a non-functioning glow plug system.
Removing the thermostat or installing a lower temp thermostat.
Deactivating the Exhaust Back Pressure valve on the turbo.
How many of us dont have a working EBPV!!!!!!!!!!!
I have seen the buildup it will get on the valves. This can cause a sticking
valve and have seen the buildup flake off and get in between the valve and valve seat.
Op.
Correct. With the damper aligned to the cps it will bleed down the lifters
on the rocker install.
Was the bad rod on the intake or exhaust?(severe bent)
Bill
dothedew192
01-10-2013 09:16 AM
