Fellas,
More and more i am feeling worse braking. Sometimes it is like a new truck and other times it goes way down. The fluid level is good. But the other day i got out of the truck and heard a hissing sound. I threw the hood up and it is coming from the booster area. Could it just be a vacuum line leaking? Where could it leak from around that area if it is not a line. The hissing lasts for a few seconds and is gone.
Does it hiss while you are holding the pedal down. It's either the booster or a line or plastic t connection somewhere. Look very closely at all hose and connections.
well i definitely cant hear it with the truck running but i will have my dad help me test it with some soapy water to find the gremlin! Heres to hoping it is a fitting or hose! hahaha
I was just coming here to post something similiar. We have had a our junker 85 f250 for a few weeks now and just got done overhauling the engine and fluids and the brake light went on by itself for the first time since we had it
I can't say we know what "normal brakes" feel like on this truck, but haven't noticed any major issues on that front.
Anyways the truck had been in the garage for a few days getting worked on and my brother started the truck while I was standing near the drivers side with the hood up.
He turned off the engine rather quickly after startup for whatever reason and that is when I could hear a hissing noise for a good 5+ seconds until it went away. It sounded like it was coming from around where the brake fluid goes into, high and near the firewall.
Looks like I need to get a vaccum gauge and start at the pump since I have no clue about the history of my setup. Altough now that I have read a bit, seems I have a leak for sure reguardless.
I don't think soapy water is a good idea. First, its vacuum, so you won't see any bubbles. Second, you could end up sending that soapy solution through the vacuum pump and shorten its life span.
First thing I would try is to pull the vacuum line from the vacuum booster about a minute after shut down (or after the hissing noise stops).
A good system will have a nice hiss when you break the seal and should hold a vacuum for several hours after shut down. This will confirm if this is indeed a vacuum problem.
Easiest way to track it down would be to try and follow the hiss by ear to where its coming from.
Could be a rotted line, loose connection, rusted vacuum booster, rusted vacuum reservoir chamber (coffee can on the driver's side plastic inner wheel fender).
Just remembered you have a C6 transmission. Is it still shifting normally?
pretty sure it isnt a vacuum issue, zero shifting problems and i have vacuum for over a day later. Not sure now what the heck the noise is. Anything else make that noise in that area? Also i have no coffee can?!
Hydraulic instead of vacumn runs off your power steering. direct bolt in with ford parts off a F450.
Your truck is saying I'm looking good, running goog just a few more bucks and I'll stop good too. IT's only money.
Seriously though it is a great upgrade, way more stopping power.
ahhh very cool. I will see what i can do about that, i know of a jy that has a ford section that is fat right now. Same years or is it a range like usual?
