Dual tank ???s
Old Dec 27, 2009 | 06:20 PM
currituckF150's Avatar
currituckF150
Dual tank ???s
Is there anyone on this board that has a 92-96 F150 4x4 shortbed w/ dual tanks? I've searched everywhere that I can think of & have yet to see one. I know that the front tank will clear the transfer case because I took measurements of off my L & compared them to my 93 4x4. Did Ford not put dual tanks in shortbed 4x4s?
Old Dec 27, 2009 | 06:24 PM
Hitokori's Avatar
Hitokori
they did in the older ones
Old Dec 27, 2009 | 06:44 PM
jr32560's Avatar
jr32560
I do remember seeing them on the older ones also
Old Dec 27, 2009 | 07:41 PM
Greg B's Avatar
Greg B
They did. Should be about a 16.5 gallon tank in front and a 19.2 gallon tank behind the axle. That tank is the same on short and long bed trucks. The front tank is larger on the long bed trucks, i think about 19 gallon.
Old Dec 28, 2009 | 12:12 AM
TexasGuy001's Avatar
TexasGuy001
I have not seen any 92-96 trucks that were regular cab short bed 4x4 with dual tanks. They all had just the rear tank. I don't think it was an option for that particular configuration.
Old Jan 26, 2010 | 06:34 PM
currituckF150
update
It finally quit raining long enough for me to do some measuring on my 93 4x4 sb & my wrecked 95 Lightning. I found out that the reason a front tank isn't on 4x4s from the factory, they won't fit. The transfer case housing where the driveshaft comes out is what prevents installation. The tank would have to be modified on the front to be made to work. It can be done but I would only cut & weld on a new tank & I don't have the funds for that right now.
Old Jan 26, 2010 | 07:14 PM
jonwoos's Avatar
jonwoos
I have a 88 4x4 with dual tanks, and a 94 4x4 with single. I have not seen a 92-96 4x4 RC's with dual tanks around here anywhere.
Old Jan 26, 2010 | 09:45 PM
blakem_85's Avatar
blakem_85
I've got a '96 short bed 4x4 with dual tanks, but its also an extended cab and I'm guessing you were talking about reg. cabs. Also, both tanks are almost identically the same size, about 16.5 gallon.
Old Jan 27, 2010 | 11:34 AM
nighthawk283's Avatar
nighthawk283
My Truck is a F-150 XLT 4X4 1994 extended cab with a short bed and it has dual tank one on the driver side and the other behind the rear axle
Old Jan 27, 2010 | 12:04 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm
I think it has to do with the transmission. This is just a guess and from what I have seen with my own stuff. I have a few 87-91 trucks and have seen this. All are long bed, reg cabs. The ones with a AOD, C6, or a ZF5 had the larger midship tank. However my 91 with a E4OD has the smaller 16 gallon tank. I'm thinking and might be willing to bet that a short bed, 4X4, with a E4OD there just is not the room.
the one that posed here with both tanks what transmissions do you have?
As I said this is a guess but I know the E4OD's are longer then the others so that might be the problem.
Old Jan 27, 2010 | 01:04 PM
blakem_85's Avatar
blakem_85
Mine has the E4OD, but like I said it is an extended cab and thus has a longer wheelbase than even a regular cab long bed.
Old Jan 27, 2010 | 03:57 PM
andym's Avatar
andym
Shortbed regular cab 4x4's are very hard to find with dual tanks. I've seen one... once. It was an 87 to 91 body style and looked original.
OP are you talking about extended cab or regular cab trucks?
Old Jan 27, 2010 | 07:27 PM
jonwoos's Avatar
jonwoos
Pretty sure he is talking regular cabs.
My 94 has an E4OD, and single tank. The 88 had an AOD with dual tanks. Both regular cab 4x4's.
Old Jan 27, 2010 | 11:20 PM
Mr. Finch's Avatar
Mr. Finch
The owners manual for my 96 150 has a capacities chart. Every Truck has dual tanks except the standard cab short bed 150 (wheel base of 116.8 inches), it only lists a rear tank, does not even list the front as an option.
Old Jan 28, 2010 | 12:51 PM
Ohio Ford Farm
I still wonder if its now due to the longer E4OD trans? I know my 91 I can NOT fit the larger 19 Gallon tank in the mid ship place as the transfer is in the way and it has the smaller 16 Gallon .. Its a Reg cab long bed with 4Wheel Drive.
